Old 12-30-2019, 02:14 AM   #1
bykr
Liked 167 Times in 81 Posts
Default Re: NHRA 2020 Rule Amendment SS Intakes???
The volumes are measured without the adapters.
That's my point. If you mill the head at a severe angle won't the cc's of the cylinder head runner be reduced? You can then open the runner up in other areas to bring the head back spec. cc's. The whole point of doing it.
bykr is offline   Reply With Quote
Old 12-30-2019, 09:28 AM   #2
Bobby DiDomenico
Liked 101 Times in 52 Posts
That's what I thought. Besides a better intake you're gaining CC's to work with and possibly changing the entry angle somewhat.
Old 12-30-2019, 05:07 PM   #3
Mike Gray
Mike Gray's Avatar
Liked 691 Times in 199 Posts
I don't understand the problem if porting, polishing, welding and epoxying is already permitted?
From rule book SS heads -
Must be correct casting number for year and horsepower claimed, per NHRA Technical Bulletins or NHRA-accepted. Cylinder-head casting must also be on NHRA runner volume list as published on NHRARacer.com. Porting, polishing, welding, epoxying, and acid-porting permitted.
Old 12-30-2019, 06:33 PM   #4
bykr
Look at it this way.If a cylinder head had 200 cc port volume and you mill away 20 cc's with this angle milling. You now have a head with 180cc's that you can open up to the 200cc spec. which then could perform like a non angle milled 220cc head. Why else would they do this?
Old 12-30-2019, 11:20 PM   #5
Sean Cour
Sean Cour's Avatar
Liked 124 Times in 39 Posts
look at it this way.if a cylinder head had 200 cc port volume and you mill away 20 cc's with this angle milling. You now have a head with 180cc's that you can open up to the 200cc spec. Which then could perform like a non angle milled 220cc head. Why else would they do this?
Sean Cour
T6066 ladle
Sean Cour is offline   Reply With Quote
Old 12-31-2019, 12:55 AM   #6
SSDiv6
Get off the pipe. Your statement shows the lack of knowledge of porting cylinder heads.
It is not about volume, it is about CSA, volume and shape of the port. You can have a 230cc port volume that is outperformed by a 200cc port volume.
Old 12-31-2019, 03:42 AM   #7
bykr
You can, but with equal port configurations which will flow more? Duh. Why do think they're doing this angle milling, to make the intake fit better-lol
Old 12-31-2019, 11:23 AM   #8
I don't race Super Stock anymore. I have enough trouble racing Stock, lately. I don't care what you guys do, and not going to suggest anything here.
I can tell you this.
I realize they didn't measure port volume in the old days.
So you guys can call this stuff cheating, being innovative, gettin' competitve, whatever you like but , if Farmer, Greg X , or Marty Barrett were still with us, the first time they laid eyes on this stuff, they would have called it ..
"buh bye"
Old 12-31-2019, 03:23 PM   #9
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
"buh bye"
Mark,
The "First" word is the key. They would never have passed this stuff as you call it, then after multiple passing's,and multiple years,change their mind and say " to all those guys we told it was Ok..... please junk your stuff"
Jeff Niceswanger 3740 SS
Old 12-31-2019, 02:20 PM   #10
Tom Broome
Liked 88 Times in 43 Posts
Well....He may not be a "renowned head porter", but he has enough common sense to understand that if you lose volume by drastically milling the intake surface, you gain the ability to change the "CSA, Volume and shape of the port".....To use your phraseology.
Perhaps you shouldn't take his statement as an absolute.
Tom Broome is offline   Reply With Quote
