Liked 1,937 Times in 582 Posts
Its the best way to go if you are in a class that requires a guard on the flywheel/ Bell housing. I have done several on Powerglides and they work real well.
Mike Pearson 2485 SS |
Liked 52 Times in 32 Posts
If you use a Bell that is easily removed and sent back for recert and a good quality Trans blanket, you'll save much $$ and frustration.....Worked for me!!
Liked 133 Times in 76 Posts
They are nice and strong but they are also thicker and bigger. That might be a factor in a car with a stock floorpan transmission tunnel. I have a 3rd gen F body and the drivers side is very tight to the bell.
Liked 205 Times in 93 Posts
the trans must come apart to install?
I have done several powerglides with out disassembly.
Unless the Bell is specific to a aftermarket Case, (Reid, etc.) they will bolt on with your existing pump bolts. The tricky part is the Sanitary cutting of your existing stock Bell
SC 707Y |
so no trans shield required if ultra/bell used ?...didn't realize that...
Liked 231 Times in 107 Posts
Thus, my request to allow removable tunnels in stock that was shot down. It's a shame they don't understand that people want to make a car safe but not such a P.I.T.A. to work. on.
#9 | |
Liked 320 Times in 102 Posts
and don't forget those dangerous glass windows because we would all be safer with Lexan.. Why don't we just leave Stock alone for a while rather than trying to " Fix it"
You're probably right. Lexan would make it safer. I'll let you fight that battle. Just don't understand NHRA requires same safety equipment in a stocker VS Super Stocker but getting it to fit in a non-massaged tunnel is impossible on some cars. Not aware of Super Stockers running Lexan. ??
