#1 | |
Liked 7,761 Times in 1,741 Posts
Now, sorry for getting long-winded but the reason I wrote this is I was having a conversation with another acquaintance of mine yesterday and one of MY combos came up. Now, said combo will run MUCH better with a smaller carb on it but the original, correct numbers carb (I have it) is a big carb. The problem is that the NHRA throttle bore and venturi spec are for the small carb. Do I run the "correct" carb or do I run the "in-correct" carb with the smaller specs? If I use the "correct" # carb, I take the chance of being tossed for too big a carb. If I run the "correct" spec carb, I take the chance of being tossed for too small a carb. In a situation where the guide contradicts itself, I really am not sure just how the chips might fall. Now when you're thinking of the correct answer remember, I'm the guy who was tossed at Indy once because my heads looked "too stock".
Liked 316 Times in 61 Posts
Billy, I don't see how you could have a problem if your carb meets NHRA specs. But you really should be discussing this with NHRA.
Bob Shaw V/SA 515 |
Liked 165 Times in 59 Posts
[QUOTE=Billy Nees;604497]To answer your question Garrett, no that exact scenario has never happened to my knowledge. BUT, a close acquaintance of mine was at a Divisional race a couple of years ago and was "spot" checked. The Tech Man wanted to see his carb and he complied. The carb on his combo was the ONLY number listed for his combo and (in fact) was the original carb for the car. Tech Man measures carb, carb comes up WAY (WAY WAY) too small, Tech Man wants to know why his carb is so small. When acquaintance tells Tech Man that it is the original and correct carb, the Tech Man doesn't toss him but tells him not to come to another race with THAT carb on the car.
Now, sorry for getting long-winded but the reason I wrote this is I was having a conversation with another acquaintance of mine yesterday and one of MY combos came up. Now, said combo will run MUCH better with a smaller carb on it but the original, correct numbers carb (I have it) is a big carb. The problem is that the NHRA throttle bore and venturi spec are for the small carb. Do I run the "correct" carb or do I run the "in-correct" carb with the smaller specs? If I use the "correct" # carb, I take the chance of being tossed for too big a carb. If I run the "correct" spec carb, I take the chance of being tossed for too small a carb. In a situation where the guide contradicts itself, I really am not sure just how the chips might fall. Now when you're thinking of the correct answer remember, I'm the guy who was tossed at Indy once because my heads looked "too stock".[/QUOTE run the carb that the spec calls for in the nhra specifications guide ,, if you have information that can prove the correct carb along with throttle bore and venturi ,contact nhra tech official and plead your case have both carbs on hand at your next divisional race and let them decide I also haven't seen any +/- spec on carb bores or venturi's Last edited by gmonde; 12-23-2019 at 08:26 PM. |
Liked 10,725 Times in 2,233 Posts
"Too Stock" ...................
Liked 254 Times in 78 Posts
I was under the impression that NHRA tech really doesn't pay that much attention to carb numbers anymore, just the specs. To easy to change on some carbs. If you have an original carb that doesn.t match specs I guess you would have to plead a case with NHRA to get spec changed. Wouldn't plead a case if the wrong spec helps me though! Merry Christmas!
Mike Moller NHRA 203 Q-R-T/SA |
