Old 12-23-2019, 12:46 PM   #1
Jim Kaekel
Liked 531 Times in 108 Posts
Default Re: th 350 ultra bell
If your car has a tendency to break bellhousings, yes. I would recommend taking the trans case to a competent machinist so it can be cut and the bell housing be registered so that it can be installed properly.
Jim Kaekel 3836 STK
Old 12-24-2019, 12:04 AM   #2
e vassar
Liked 271 Times in 107 Posts
I wouldn't pull my trans out just to put one on , but if it's already out,its a no brainer,,considering the cost.
Old 12-24-2019, 12:22 AM   #3
MR DERBY CITY
Liked 7,935 Times in 1,518 Posts
There is absolutely NO need to install a ultra bell on your tranny...UNLESS you are cracking the case. After you have cracked ONE case,...it’s a lifesaver....of course my ole buddy Captain Jack cracked 2 cases before he bought the bell.....
Old 12-24-2019, 01:14 AM   #4
richie 2
Liked 205 Times in 93 Posts
thankyou !!!
Old 12-24-2019, 10:37 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,919 Times in 576 Posts
Its the best way to go if you are in a class that requires a guard on the flywheel/ Bell housing. I have done several on Powerglides and they work real well.
Mike Pearson 2485 SS
Old 12-25-2019, 11:02 AM   #6
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
If you use a Bell that is easily removed and sent back for recert and a good quality Trans blanket, you'll save much $$ and frustration.....Worked for me!!
Dano is offline   Reply With Quote
Old 12-25-2019, 12:22 PM   #7
Eman
Liked 133 Times in 76 Posts
They are nice and strong but they are also thicker and bigger. That might be a factor in a car with a stock floorpan transmission tunnel. I have a 3rd gen F body and the drivers side is very tight to the bell.
