Old 12-22-2019, 03:56 PM   #3
NORMAN BARNARD
Liked 2 Times in 2 Posts
Default Re: So I just ran the class final at Indy.......
Billy, being from the carolina's an also run there. The answer 's
is,,the guy with the biggest gun.....(just kidding)...
Correct answer is the spec. Size of the carb. That's specified, but not "bigger". If the guy with the smaller carb. Is faster, better look
for a vacuum leat above the throttle blades or some mods. To the booster cluster.... (old trick)
NORMAN BARNARD is offline   Reply With Quote
