Old 12-22-2019, 03:19 PM   #1
JeremyDuncan
Liked 354 Times in 79 Posts
Default Re: gt class question
Originally Posted by FireSale View Post
Then you are probably right. Where did you see 307 as the GT factor? I found 304.
Only drag racers split hairs over 3 HP and 39 lbs......
SS factor for the Chevy II/NOVA 327 is 307 for OEM. 67 327 GT is as you stated 295 OEM/304 replacement.
Traditional SS factors for 327 275 in a Camaro versus a Chevy II are different.
JeremyDuncan is offline   Reply With Quote
Old 12-22-2019, 05:03 PM   #2
jaf2021
Liked 5 Times in 5 Posts
Thanks for the information Jeremy The car is a wagon if it makes any difference Sorry I should have stated that If any difference please let me know I’m trying to understand this
jaf2021 is offline   Reply With Quote
Old 12-22-2019, 05:18 PM   #3
JeremyDuncan
Yes it does change things. Not sure wagons are eligible to run SS GT.
Old 12-22-2019, 06:44 PM   #4
jaf2021
Jeremy I found a picture of Greg Luneack nova wagon with gt/ha and ss/ka on the window
Old 12-22-2019, 06:53 PM   #5
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
66 Chevy II Wagon was available as a 2-door, which is a requirement for GT. Check the weight and go from there.
Dale Shearon
68 Mustang 6394
Old 12-22-2019, 07:02 PM   #6
jaf2021
Yes it does list station wagons in the rule book
Old 12-22-2019, 07:48 PM   #7
FireSale
FireSale's Avatar
Station wagon shipping weight is 3062. The heaviest auto gas V8 is the 327/275. It has a SS rating of 307 and a GT rating of 295 with OEM heads. I don't know which to use. Classification weight is figured without factoring in driver weight.
Quotes are from the 2019 GT Weight section. Math is mine and not under warranty....
"Shipping weight will be determined by using the power to weight factor of the vehicle with the heaviest gasoline engine and appropriate transmission"
3062/327 = 9.36 lbs per hp.
"..and multiplying the factor times the horsepower or performance rating"
9.36 x 295 = 2761 (pick one)
9.36 x 307 = 2874
"The proper class weight will then be determined by dividing this figure by the horsepower or performance rating of the engine used. Class is determined without driver weight."
2761/295 = 9.36
2874/307 = 9.36
GT/GA 9.00=9.49 lbs per NHRA factored HP
"Shipping weight of vehicle may be adjusted a maximum of 250
pounds to fit car in class."
+250 =3011 = 10.2 NHRA factor GT/IA 10.0-10.49
-250 =2511 = 8.5 NHRA factor GT/FA 8.5-8.99
EDIT
Indexes
GT/GA 10.40
GT/IA 10.65
GT/FA 10.25
Dale Shearon
68 Mustang 6394
Old 12-22-2019, 10:58 PM   #8
Liked 5,121 Times in 1,952 Posts
Nope..Better lay off the rum and egg nog ;-)
Old 12-23-2019, 02:17 AM   #9
FireSale
FireSale's Avatar
Not trying to be difficult, but it does have production numbers and a vin code. The info is from a GM database at OldRide.com
https://www.oldride.com/library/1966...olet_nova.html
MODEL NUMBER 13
BODY/STYLE/NUMBER 35
BODY STYLE AND SEATING 2 Dr Station Wagon
FACTORY PRICE $2,430
SHIPPING WEIGHT 2,855 lbs
TOTAL PRODUCTION Note 2
NOTE 2 Chevy II Station Wagons, rounded off to the nearest 100, Chevy II 6-Cyl - 16,500 and Chevy II V-8 - 4,900
The VIN should be 1 (Chevy) 13 or 14 (6 or 8 cylinder) and 15 (2 door station wagon)
Dale Shearon
68 Mustang 6394
Old 12-23-2019, 03:03 AM   #10
Rory McNeil
Liked 1,104 Times in 302 Posts
Marks right, regardless of what some website may claim, there were no 2 door Chevy 11 station wagons made, at least by GM. you may have seen a couple of 2 door wagons around Seattle, like Al Chinns Nova, but that was fabricated, not original. That said, Chevy did make some 2 door Chevelle wagons in 1964 and 65. Pat Brooks runs a 64 Chevelle 2 door wagon in Stock in Div. 6, and also has another street 64 2 door wagon. But other than the 64-5 Chevelle, there were no Chevrolet 2 door wagons after 1960, until the Vega came out in 1971.
NHRA 6390 STK
M/S 85 Mustang
