Old 12-06-2019, 06:27 PM   #1
SDT1DYI
Liked 455 Times in 147 Posts
Default Re: Duramax Allison issue
No I did not change transmission fluid. I did add additional Dex Vl after changing filters. I did use this same manufacturers filter in my 2012 3500 Durmax/Allison with no issues. After changing filters on my 2018 , when i was off the throttle , coming up to a stop light, it would bang hard when it down shifted into 1st gear. Up shifts under power , no issues. Only downshifting.
It's all I changed ( other than engine oil and filter ). I purchased and installed the GM OEM filter, added addition Dex Vl and the downshifting issue has not happened since
Hope this saves other Racers some headaches
Steve Teeter STK. -380/6283.
SDT1DYI is offline   Reply With Quote
