Liked 239 Times in 114 Posts
Allison was part of GM Hydramatic when the 1000 was developed . The Engineers from Indy work side by side with us in Ypsilanti . When GM went through bankruptcy Allison was spun off but the only Allison trans that remained with GM was the 1000 because it was in most of the 1-ton pickups . I think it's still built in Baltimore . Also Castrol developed the fully synthetic fluid Trans-Max , and later Allison re-named it Trans-Syn . It is a very good Automatic Transmission Fluid
Liked 208 Times in 45 Posts
Would the Trans Syn fluid be better in a 2001 1000 model Allison than the Dexron?
Guest
Posts: n/a
Liked 456 Times in 148 Posts
No I did not change transmission fluid. I did add additional Dex Vl after changing filters. I did use this same manufacturers filter in my 2012 3500 Durmax/Allison with no issues. After changing filters on my 2018 , when i was off the throttle , coming up to a stop light, it would bang hard when it down shifted into 1st gear. Up shifts under power , no issues. Only downshifting.
It's all I changed ( other than engine oil and filter ). I purchased and installed the GM OEM filter, added addition Dex Vl and the downshifting issue has not happened since Hope this saves other Racers some headaches Steve Teeter STK. -380/6283. |
