Old 12-02-2019, 01:19 PM   #1
Tom Goldman
Tom Goldman's Avatar
Liked 888 Times in 239 Posts
Default Re: Setting Up Suspension for SG
Originally Posted by StompNDump View Post
So basically the wheel stand is just for show? No added advantage of doing so? My bars dont need to come off for loading or unloading so maybe I would just leave them on.
Some cars need to yank the wheels up to hit the tree ,others don't . ..Horsepower ,converter ,chassis setup ,driver all factor in .
letting my car do a bit of a wheel stand helps eat a little 60' so I don't need as much in the timer.
Old 12-03-2019, 12:50 PM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
My dragster is much, much faster than my door car. My door car does wheelies though, so I usually leave the dragster to sit in the garage.
S/ST 51
S/C 53
Old 12-04-2019, 08:18 AM   #3
sst5167
sst5167's Avatar
Liked 17 Times in 9 Posts
Like most things, there are many different opinions and ways to go about making a super gas car work.
Wheelie bars are set high, or left off because they can cause the tire to "unload." The car is usually already coming on the throttle stop while it's riding the bars. The power being taken away while on the bars hard is what can cause the car to unload.
Like said before, some guys like to get their car to "jump" out of the lights for a quicker reaction time. But it can also slow your e.t. down so you need less time in the throttle stop timer, which will allow the car to come back to wide open throttle sooner for a bigger top end charge.
sst5167 is offline   Reply With Quote
