Old 11-10-2019, 08:22 AM   #1
Billy Nees
Liked 7,659 Times in 1,726 Posts
Wink Re: X /Stock ?
Sounds like this deal has "Dime Rocket" written all over it!
Oh, oh, wait a minute, umm............. this sounds like a real high dollar deal that would cost the Racers a fortune to get into. It would probably lead to lots of high end sponsorship involvement and make the NHRA BOD a fortune!!! As a little guy, I don't like it. ................
Billy Nees 1188 STK, SS
Old 12-13-2019, 05:21 AM   #2
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Default Re: X /Stock ?
How about a 3rd Generation Camaro or Firebird? I know the 1985's came with a Iron Duke 151 TBI Almost started the project years back, parts were collected, still have, like a Mini-Spool for a 7.5 rear with 4:56 gears..all types of blocks..even a couple with Chevy bellhousing bolt patterns. Would have fell into W , maybe a little heavy too..took to track once just as it was..ran 19.60's..slipped on a smaller rear tire, ran a 19.30..
Will Lamprecht
65 Impala I/SA turning into a I/Stick
1997 Mustang V6 T/SA project with brother.
Old 12-13-2019, 12:09 PM   #3
Liked 5,093 Times in 1,941 Posts
Will Lamprecht
A bit high rated for W/Stock, but I'm sure it would run under the index. Qualifying at Indy would be a different story. You have your choice of a Vari-jet or TBI.
S10 134 might be good.
Who was the guy from Memphis , associated with RHS or Comp Cams that had one about a decade ago? He managed to get 5 hp put on the automatic (but not the stick ;-) )
Old 12-14-2019, 08:41 AM   #4
Billy Nees
Mark, you're just itching to do a 4 cyl. Chevy II aren't you?
Old 12-14-2019, 10:13 PM   #5
Cannot tell a lie...
As soon as someone donates a 62-3 100 2 dr. or sells me one at scrap value.
I might even paint the engine Chevy orange :-)
Old 03-18-2020, 03:01 PM   #6
RickF
Is the S-10 134 a feasible project, just curious.
RickF is offline   Reply With Quote
Old 03-18-2020, 03:35 PM   #7
Billy Nees
Someone went fast enough with one to get some HP so I would guess that it's feasible.
Old 03-18-2020, 06:33 PM   #8
Bear in mind that the modern EFI , roller cam engines seem a little high on their hp ratings, compared to early model, 4 and 6 cylinders combos. Don't let that discourage you. They are designed for maximum torque, using a limited amount of displacement for, mpg and emissions reasons.
Old 11-18-2024, 03:51 PM   #9
Chuck Weissberg
Liked 47 Times in 24 Posts
Will Lamprecht
I believe Billty Nees said the mains cannot hold up on the iron duke 4
Chuck Weissberg is offline   Reply With Quote
Old 11-18-2024, 04:50 PM   #10
Billy Nees
Nope, it wasn't me. But someone on here did say something like that. After thrashing (trashing?) 301 Pontiacs for a few years, I wouldn't be concerned about the bottom ends in the iron dukes. Believe it or not, they use a lot of the same parts.
85 Camaro/Tech4 has been on my to-do list for a while. It's better than the earlier ones.
