Old 09-16-2019, 01:08 PM   #31
Rose Racing
Rose Racing's Avatar
Liked 227 Times in 74 Posts
Default Re: 1971 Torino 500 2 door hardtop
Originally Posted by Bill Harris View Post
https://opentrackerracing.com/ has all the rollerized front suspension stuff and it is excellent. I have been told that it is not legal in Stock, but is in SS, but who knows for sure? I used it on a 69 Mustang for SS/GT several years ago and the guy who did the front end alignment couldn't believe how well it worked.
If your interested in 429SCJ stuff, I have a bunch of it.
I'm not sure Bill did the 429 scj come in a Torino 500? I thought maybe GTs or Cobras?
Rose Racing is offline   Reply With Quote
Old 09-16-2019, 08:44 PM   #32
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
The 500 has a 429 listed at 370hp in the Stock Car Guide. The Engine Blueprint document lists that as head # D0OE-R. MustangTek identifies it as D0OE-6090-R 70-71 429 cj/scj. It carries MustangTek's "verified" checkmark.
Dale Shearon
68 Mustang 6394
Old 09-18-2019, 02:04 PM   #33
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Originally Posted by Rose Racing View Post
and what do you Cleveland guys run for roller rocker arms?
PRW, These were considerably cheaper when they 1st started selling on E-Bay.
https://store.prw-usa.com/0246003-bi...l-rocker-arms/
Dave Noll, EF/S ,?/SA 6526
Dave Noll is online now   Reply With Quote
Old 09-19-2019, 11:44 AM   #34
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
I have had a good experience with the PRW rockers on my stocker.
Dave Turner
SS/GT #1153
Old 09-19-2019, 03:39 PM   #35
Mike Graham
Liked 341 Times in 67 Posts
After looking at NHRA blueprints it says for 302 valves are 1.79 intake and 1.46 exhaust.... I'm sorry but this doesn't really sound right?
Don't pay any attention to anything but the blueprint spec that NHRA has. They list 2 different valve sizes for the 302 1.79 1.46 1.78 1.45. Remember you have +.005 and -.015 tolerances. If you are careful you can run the same valve in either engine. You can get a Torino to 3410 with driver. We did it.
Mike Graham is offline   Reply With Quote
Old 09-19-2019, 09:21 PM   #36
Rose Racing
I did not know of the tolerance rule. I cant find any 1.79 intake valves except for a 4.6 ford
Old 09-19-2019, 11:23 PM   #37
Mike Graham
We bought 351w valves and cut them down. You can use 1.78 valves as 1.79,but check them and make sure they are an the big side. 1.79-.015 = 1.775 so you can use the 1.78 valve in place of the 1.79. With the 1.08 carb the .015 loss in valve size doesn't make any difference.
Old 09-30-2019, 07:34 PM   #38
FireSale
FireSale's Avatar
Stock: Cylinder Heads: Page 135 or so.
"Valve-diameter tolerance:+.005-inch or -.015-inch from NHRA Specs."
Dale Shearon
68 Mustang 6394
Old 02-09-2020, 07:57 PM   #39
Rose Racing
I got the Moser Engineering axles and spool during christmas and I still need to order Ring and pinion as well as installation kit and Spool bearings. I need to pull center section out but weather is getting in the way.... I am first going to order some transmission components before I order the rest of the rear end components because I dont see the weather breaking soon.(The car is outdoors) Bracket car is in the one car garage)
Old 02-10-2020, 02:53 PM   #40
FireSale
FireSale's Avatar
Building in the drive with a bracket racer in the only garage space......You married? If so, your wife and mine could trade stories.
Sandusky, huh? Born and raised in Toledo, here. Currently a lifer in Washington State. "Staff Photographer" at Milan in '66-'67 ish.
Good luck with the build.
Dale Shearon
68 Mustang 6394
