Old 09-15-2019, 12:33 PM   #1
jims5600
Liked 21 Times in 9 Posts
Default Re: My 1970 Slow Poke Nova Build
Just subscribed to your videos. Great videos,very informative. You work is very,very nice. Look forward in following your progress. Best of luck.
Jimmy
jims5600 is offline   Reply With Quote
Old 09-15-2019, 12:35 PM   #2
Wayne Scraba
Liked 186 Times in 48 Posts
Thumbs up Re: My 1970 Slow Poke Nova Build
Jimmy
Thanks Jimmy! I really appreciate the compliment. I'm on a tight budget, so I have to go slow...
Wayne Scraba is offline   Reply With Quote
Old 09-20-2019, 12:54 PM   #3
Wayne Scraba
Smile Custom Mark Williams 12-bolt
For the Nova "sleeper" build, I'm using a pretty cool custom built 12-bolt from Mark Williams. It's a super neat piece with 35 spline axles, a 35-spline Detroit Locker, a custom DTS case, moly axle tubes, unit bearings and more. It also looks pretty close to stock (perfect for my sleepy little Nova application). This is part one. I'll follow up with part two (axles) next week. Hope you dig it and thanks for watching! Please subscribe!
Old 09-26-2019, 02:28 PM   #4
Casey Miles
Liked 508 Times in 92 Posts
Do yourself a favor and save up for gun drilled axles, they are worth it. Also, if you're going to put an exhaust system under the car, get electric cut outs. I have both on my car and it's fun to race with.
Casey Miles
248H E/S
Old 09-26-2019, 02:31 PM   #5
Wayne Scraba
Talking Re: My 1970 Slow Poke Nova Build
I've used gun drilled axles before (first set was in 1996), but this car will see street use so its conventional axles for this go-around.
Old 09-26-2019, 02:50 PM   #6
Casey Miles
If you're going to put on an exhaust system, on my 1969 Camaro Z/28 I have a 2.5 inch flowmasters with electric cut outs. The car will run only .15 to .18 slower through the mufflers rather than open headers and they are pretty quiet. Just a recommendation from experience. What I do is run the car with open cutouts, qualify with that number, make a pass with mufflers and dial the car through the mufflers.
Casey Miles
E/S
Old 09-27-2019, 11:36 AM   #7
Wayne Scraba
Casey Miles
E/S
Thats good info. Thanks Casey!
