Old 08-31-2019, 05:53 PM   #41
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Default Re: Jason Line
Originally Posted by jimmyparker View Post
Just looked at pro stock qualifying, looks like Jason has put the Buick motor in his PS car, he is currently # 1. His C/SA runs were absolutely scary, anybody have a guess as to how much HP it takes to run these numbers in this body at 9.00 lbs. per factored hp?
660 + if it was in my car, I'm sure his is better though.
Pedigo Perf is offline   Reply With Quote
Old 09-01-2019, 10:25 PM   #42
Glenn Briglio
Glenn Briglio's Avatar
Liked 976 Times in 311 Posts
Probably doesn't make that hp.............but torque is another story
Old 09-01-2019, 10:28 PM   #43
HP HUNTER
Liked 373 Times in 129 Posts
609 observed crankshaft HP @ 130 MPH @ a 29.10 baro, but I believe he went faster than 130 MPH
Old 09-01-2019, 10:39 PM   #44
Carguy49
Liked 3,023 Times in 723 Posts
Any idea what the torque figure would be??
Lot of weight to get moving.
Ron McDowell - Did Race
Old 09-01-2019, 10:54 PM   #45
HP HUNTER
I know its over 600 TQ corrected, my question would be: how far does this engine carry HP past peak? For those not familiar with this combination.
1. Big bore 4.350 + 3.912 stroke
2. 13.3 compression
3. 2.125 Intake valve
4. .490 lift cam, utilizing which I'am sure is over 270 CFM @ 28 inches or more, with excellent low lift flow.
5. I would assume spin tron development as well.
4. 800 + CFM carb
Not to diminish the performance, because 131 MPH in a 29.10 baro @ 3635 is mind boggling in these conditions. Nice work!
Old 09-03-2019, 01:50 PM   #46
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
2. 13.3 compression
4. 800 + CFM carb
That means in cold weather that is potentially a 9.50 Car !
Dan
Old 09-03-2019, 02:00 PM   #47
Hacksaw
Liked 314 Times in 177 Posts
No way. Stop dreaming.
Old 09-03-2019, 02:12 PM   #48
Lyn Smith
Liked 1,002 Times in 203 Posts
This combination has to use the smaller q jet.The 455 Buicks did not get the bigger one till 1971.
Old 09-03-2019, 04:35 PM   #49
Glenn Hayes
Glenn Hayes's Avatar
Liked 18 Times in 12 Posts
Is there a video out there of Jason's Buick at Indy?
