Old 08-27-2019, 10:46 AM   #1
Carguy49
Liked 2,951 Times in 709 Posts
Default Re: Dumbo The Flying Elephant
Sorry that you can't make Indy. I totally understand and respect your decision to pull the plug. You want the car to be right and SAFE for you and the racer in the other lane. Good luck and I hope you make it to a race soon.
Ron McDowell - Did Race
Old 08-27-2019, 01:08 PM   #2
Dissident
Liked 73 Times in 36 Posts
Hey Big Guy,
It is a bummer to miss the Big Go, but it is so difficult to debut a new racecar at the Indy event. It will pay off in spades that you skipped the Indy gig by remembering "softly, softly....catchee monkey" as you sneak up on problems and resolve them so it will pay you back handsomely.
Best to you and yours,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 08-28-2019, 09:32 PM   #3
Liked 10,721 Times in 2,232 Posts
We got the two step working, thanks to David, Chris, and Bob. My job as usual was to hold the flashlight and not shine it in anyone's eyes. The most fun I had was applying the brake, turning the ignition on and off, and overhearing what to do to make stuff work.
Old 09-01-2019, 08:47 AM   #4
Frank Castros
Liked 2,727 Times in 961 Posts
Larry,
Would you mind posting photos of Dumbo at the Gateway test session?
Old 09-01-2019, 12:02 PM   #5
Dumbo is done for the year. It seems we got a block with a porosity problem. I guess some days are luckier than others. Just have to remove disassemble, fix, reassemble, dyno, install, and test. That should keep me out of the bars for awhile.
Old 09-01-2019, 12:50 PM   #6
BRETV
Liked 776 Times in 199 Posts
Larry, same with my new project. Went to run the car and found we had a bad cylinder. My future plans sound like yours. A lot of future work and $$$. Good luck with dumbo.
Bret Velde
2003 ???
BRETV is offline   Reply With Quote
Old 09-02-2019, 09:29 AM   #7
Frank Castros
Larry,
Correct me if I'm wrong, but your grade points for 2020 will be a challenge for you?
