#1 | |
Liked 113 Times in 41 Posts
Yes, if you hit the index or set a record as an AH/SM you can expect to get a full super stock style teardown. That is straight from NHRA tech dept. No, I do not believe a top running hemi car being able to run .65 under is a gift. It is a highly refined combo that, again, will not "magically" go faster as a comp car. And that is the beauty of comp. If one of these cars does go .65 under in elims, then the cic starts to come into affect and will in turn self regulate the index. That is the basis of comp. Yes, I do agree with you that they need to actually run the class as it sits so that they can show in real world conditions that the index is off. Without doing a ton of research, there have been several this year that have competed. Wolkwitz, comella, welker, Bucky, pancake, and I think a few west coast guys have. I know several of my other customers considered it, but elected to stay in SS b3cause of the index. I can only speak for my current customers, but everyone I know runs their car like they are trying to set a record every time they go to the water box. Only exception is probably comellas dart. They don't run it as hard but they are chasing points (and kicking butt!) And they have the red cuda to run shootouts with. First, minimum weight for ss/ah is 3200. Second, you can't compare a/sm and ah/sm. A/sm is allowed two dominators, any port work, titanium valves, aluminum rods, billet cranks, vacuum pumps, longer wheelie bars, 5 speeds, carbon brakes, etc. Just the 5 speed alone is probably a tenth..... As far as where is the data? There is 50 years of it. Or the last ten years of hemi shootout at indy. We compiled the data of the last 4 years of the shootout at indy versus comp qualifying and submitted that to nhra. When you look at that info, same track, weather, track, etc, it's pretty obvious where the index needs to be. |
#2 | |
Liked 88 Times in 43 Posts
That's good data, but it's still not data from those cars running Comp. Your argument would be a lot stronger with more passes in Comp. Lots of other racers go out there and struggle in Comp. Why do the Hemi cars deserve special consideration? I can only presume you still feel that a 9.05 index is still fair to the other racers in Comp? Is it fair to Comp to let a Hemi racer in and cost the class by losing other racers? An occasional Hemi car is worth losing regular competitors? That's what will happen with a "gift" index. |
Liked 29 Times in 14 Posts
I hope you realize the Holt brothers both have an F/D and have raced Comp for several years. Everything they stated is valid.
Thanks, Ron |
Liked 174 Times in 39 Posts
According to Nitro Joe's stats, only 3 classes have had more participation in comp this year than AH/SM so far, B/DA (11 cars), C/DA (7), and A/EA (7). Five others have had the same amount of cars as AH/SM (5), C/SM, G/AA, C/A, AA/AM, and C/ED.
The best run has been Bucky Hess with a -0.31 8.44 at Reading, put him #27 out of 31 cars and the last car that actually ran under the index in qualifying. A 9.00 index would have made him #16 at -0.56 under, and a 9.05 index would have made him #9 at -0.61 under. In 2018, the max number of comp cars in any class was B/DA with 13. SS/AH had 38 cars run in 2018. 2017 was 18 B/DA cars, 36 SS/AH. 2016 17 B/DA, 32 SS/AH.2016 12 B/DA, 39 SS/AH. So it appears that there has been significantly more participation in SS/AH than any single comp class for the last several years. A number of these entries are not competitive with the fast guys, but I believe there have been quite a few different cars and engine builders running ETs near the top over the years. The comparison was brought up between AH/SM and the other SM classes. An A/SMA is 400 in at 2750 lb, once you factor the 250 lb reduction for an automatic, that's 6.875 lb/in. An AH/SM would be 150 lb lighter at 6.875 lb/in than at 7.2 lb/in. So you take the 8.53 A/SMA index and add 0.15 for the weight (maybe a hundredth or two less?) you get 8.68, only 0.07 faster than the current AH/SM index. Does anybody really think all of the stuff you can do in the base SM classes over a Hemi car is worth that little? Comp needs more cars and a lot of the guys with SS/AH cars like to run them flat out all the time, comp is a great place for that. It's tough to show up at a race with the mindset that you have one of the fastest cars in your class (that's had a ton of rich and talented guys run it over the years) and you probably don't have a chance in hell of winning a round, much less the race. Just my 2 cents as a comp fan who that would love to run the class someday, hopefully sooner rather than later.
3207 D/SA, C/ED |
Liked 679 Times in 180 Posts
Sure it is a highly refined combo, so are the other cars that run .35 under. It's hard not to see it as a bunch of rich guys that think they have spent enough money and deserve a "good index".
SIR, that is EX rich guys. I will sell mine "on the hoof" at Indy. CHEAP |
#6 | |
Just for grins, lets pretend I own a Super Stock Modified Cobalt and I'm exploring moving to Comp. I would do a quick comparison of classes between Comp and Super Stock with virtually identical weight breaks and rules. Lbs/ci_____SS class-Index____Comp class-Index_____Change+/- 7.5________SS/AM--9.00______A/SM--8.45_________-.55 8.5________SS/BM--9.20______B/SM--8.66_________ -.54 9.5________SS/CM--9.50______E/SM--9.10_________ -.40 10.5_______SS/DM--9.75______G/SM--9.33_________ -.42 So, if we look at Hemi cars: 7.2________SS/AH--9.60______AH/SM--8.75_________-.85 Lets try 9.05: 7.2________SS/AH--9,60______AH/SM--(9.05)________-.65 On it's face this makes 9.05 look like a number that didn't get pulled out of thin air. But we need to consider the SS/AH index could be a little "soft" compared to SS Modified. How far under in Super Stock do the typical SS Modified cars qualify versus SS/AH. That will define how "soft" the relative indexes might be. Andrew, you mentioned the Nitro Joe Stats, Five cars in AH/SM. All at national events? That's 5 races with Hemi cars, or five different cars at races? So, what does a SS/AH racer do? Tough call. Show up in Comp and hope you get past first round and run all out, or run Super Stock and try to try to run a dial in for more rounds? |
#7 | |
Imo, I think Bucky Hess and Gary Wolkwitz (top 2 Hemi cars in AH/SM this year) have probably put as much time and money into their combos as anyone in any class in comp. if they aren’t competitive with the current index, who will be?
3207 D/SA, C/ED |
#8 | |
Hasn't the class stagnated some without the Wescott's? Did the record go to minimum and get reset slower? If I'm not mistaken SS/AH runs the same weight with or without an auto transmission. Are Hess and Wolkwitz running stick or auto? If auto, could the sticks be faster? |
