Liked 20 Times in 12 Posts
For those that may have the slip-on collectors and wish to install an O2 sensor in them, what is the consensus on sealing the collectors to the primary tubes with an extreme high temperature sealant, such as this:
https://www.fluidsealingsupply.com/d...RoC5JoQAvD_BwE I'm guessing that one downside would be that the slip-on collectors would then be much harder to install or remove from the primaries. |
All good information above but what I was told to be more concerned with getting it in the proper position behind the merge 6 to 8" would be much more important.
Liked 7 Times in 5 Posts
does the # matter that much as long as its consistent enough to see change once you know what the engine likes you can adjust to that. i always think of it as a tool to better understand how changes and weather effect the car and not to chase a magic #
Liked 70 Times in 31 Posts
Put the O2 in a primary tube and it works great all the time except if there is an issue with that cylinder. I originally had mine in a collector and continually fought it. Moved it to a primary a couple years ago and never have a problem.
Darrel Goheen 785-623-7021 Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427 Tehnician for JustAnswer.com |
