Old 08-16-2019, 08:38 AM   #1
Nmbr1GMfan
Default Re: spiral or ring type piston pin retainers
Originally Posted by Rich Biebel View Post
Todd I don't know the exact reason for your engine failure but I would not change what has worked successfully for many years.
I have no idea why a piston company would change to something different.....
I've used spiral locks as I said for many years and the pins don't have a lot of movement side to side between the locks. Never had one come out....
I always make sure the pin is free to move back and forth between the locks after assembly and use a heavier type assembly oil on the pins and pistons....
Round wire locks might work fine but you won't find them in my engine. Now that I know these are out there I would make sure any pistons I buy have Spiral lock grooves and locks.....or I'm not buying them...
My dragster engine is a 565 and has Diamond pistons with spiral locks....I built it......It's 6 years old and has hundreds of runs on it.....and has been apart for inspection and some fresh parts.
I built engines for myself and many others for years and years......
Rich, I agree with everything you've said. Why the piston manufacturers have gone to a round wire lock I can't comment on, I just don't know. What I do know is a round wire lock will not work if the piston manufacturer doesn't machine the groove properly. Not sure if the same applies to a spirolox groove or that type of lock is more forgiving to machining discrepancies.
Todd Greene
Old 08-16-2019, 02:50 PM   #2
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Unfortunately in this day and age manufacturers have to have something new to help them sell and be different enough to be the latest "new & improved"
Sometimes change is good if it's made for the right reasons.
Sometimes change is bad if it's made for the wrong reasons.
I have been racing with my partners for 50 years and always on a tight budget. No money makes it difficult to recover from adversity.
We raced what we built. The dollars spent had to produce.
Why would I risk our racing money on a trick of the week.
I know that I will take some heat for this post, but that's OK because I've handled heat my whole life...
As I remember back there was a very well known Junior Stocker guy that had written on his car "Trix are for kids" and it's still true today.
Bob Mulry 7516 STK
A & M Motorsports
Old 08-16-2019, 05:53 PM   #3
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Here is a joke that might fit for this...
Consider the new round wire pin locks "the green alternative "
In my experience if it says its "green" It just doesn't work worth a you know what....
Plenty of modern things are better and may take some getting used to.
Plenty are not and you regret getting sucked into the marketing...
I would assume a round wire lock would work fine in a properly machined groove with a pin finished the way it would need to be to work with that lock....and all proved by testing...
But exactly what is the reason to make a change from what has worked for decades.....
You have to ask yourself why did they make this change.....There is NO advantage or improvement since what they changed was not failing....
Rich Biebel
S/C 1479
Stock 147R
Old 08-18-2019, 05:52 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
I have engines with both dual spiral locks ,and the round wire rings.
Mahle has the round wire clips in their specialty performance line.
Since the wire ring engine has not been pressed into service yet ,I cant personally attest to their durability.
That being said , my finger tips were in much better shape after assembling the engine with the wire clips !!
Back in the 80's the machine shop that did my work was building some mighty successful Dirt Modified engines with the wire clips , I cant remember them having any failures. . ...Plus they had some Cosworth engines there which also had them.
Old 08-18-2019, 10:45 PM   #5
spike1
Liked 53 Times in 16 Posts
I have been running round pin rings (CP) for over 2 years now (200 runs) in my 5.7 drag pak up to 8400 rpm and never had a problem with ring clips, pins or piston.
spike1 is offline   Reply With Quote
Old 08-19-2019, 12:10 AM   #6
rawhide
Liked 7 Times in 5 Posts
I have not seen a Cosworth piston that did not have round wire rings in them and they started business in 1959. The last V8 Ford Formula One engine they did ran at 19500 rpm without any failures that I can remember. Even flathead Fords had round wire locks.
rawhide is offline   Reply With Quote
Old 08-19-2019, 08:46 AM   #7
Rich Biebel
I was in the engine machining and building world for many years and not once can I recall seeing round wire pin locks....from any of the major piston manufacturers.
Round snap ring type was common.....double per side and then spiral locks were the most common.
Yes they tear up your fingers and usually end up with some blood involved.
They made a tool for them but I developed a pretty easy method of getting them in and out.....no blood....usually...
I would guess the round wire lock does not pound out the groove like a flat lock does making it harder to disassemble pistons after some use...
I also assume the round wire lock groove is cut to fit the lock and if done wrong bad things happen...…
I usually Learn something new everyday...but I'm sticking with spiral locks.....LOL
Rich Biebel
S/C 1479
Stock 147R
Old 08-21-2019, 02:26 PM   #8
Tom Broome
Liked 88 Times in 43 Posts
I still prefer spiral locks also. But there were a few somewhat major piston manufacturers many years ago that utilized round wire locks. One you might have heard of....Cosworth. We used lots of them in the 80's on Buick R&D at the shop I worked at. Cosworth seemed to have it figured out, even the "on center bore" V6 Buicks still had rod offset issues and I can't recall a single Cosworth piston pin issue.
Tom Broome is offline   Reply With Quote
Old 08-21-2019, 03:31 PM   #9
Bob Mulry
Bob Mulry's Avatar
I'm not sure Rich, but I think that you might be referring to the doubled up Tru-Arc snap rings.
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 08-19-2019, 08:52 AM   #10
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
thanks guys for responses ,, I did get some helpful information from the piston manufacture as well that puts my mind at ease
gmonde
