#1 | |
Liked 225 Times in 136 Posts
NHRA SHOULD setup a reserved Seting grand stand at the tear down barn it could be more interesting than the racing?
Liked 207 Times in 49 Posts
Seems like they could tear down the 2 fastest guys from each class in qualifying. Then anyone that goes .90 under in a heads up race.
Brian Anderson 5058 B/SA 99 Chevy Camaro SS |
Liked 223 Times in 73 Posts
Sounds like some one was ask to be torn down recently at a national event and wasn't prepared. See what happens this weekend.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
Liked 140 Times in 46 Posts
I am happy to see this come back around. Please do more than 1 a year as well. Good job NHRA!
Jon Sarrett Stock 3779 |
Liked 434 Times in 116 Posts
I agree on this and should happen more often, BUT if NHRA wants to see a crank, PLEASE supply the Guy or Gal and engine picker, it is INDY and it is there garage and track, they should keep one or 2 there. hope this will keep people honest, LOL Good Luck.
Liked 262 Times in 74 Posts
Comp is allowed any internal Modifications,as is Top alcohol. If I set a record they pump the engine and check for illegal equipment and done. If NHRA wants to pull a Piston in my DOHC Comp car they are going to have a fight on their hands.
Steve Polhill 3520 STOCK, COMP |
#7 | |
There are still many things that can be checked in Comp such as making sure they run the correct size/type of carburetor. Pumping the engine for claimed cubic inches and also, to make sure they run the correct engine bore spacing. The rumor mill says there have been instances of some guys running small block Chevy engines with 4.50" bore spacing in classes were they must run the OEM, 4.40" bore spacing. |
#8 | |
Liked 81 Times in 35 Posts
Greg |
#9 | |
Liked 520 Times in 132 Posts
Liked 2,727 Times in 961 Posts
The used to do it a Ford dealership did they not?
