Old 07-08-2019, 06:19 PM   #1
pmrphil
Liked 348 Times in 152 Posts
Default Re: valve spring pressure
Originally Posted by jamie2370 View Post
350 sbc, flat tappet hydraulic cam(stocker motor) Thinking I have valve springs going causing car to not turn over 5500rpm. I used an on car spring tester. I got 110ish to just open valve and around 250ish at .500 lift(1/2" measurement), tested with that valve closed and I could spin pushrod with my fingers. Looking at Pac 1409x , it shows like 150/390. I'm thinking the springs are gone??
Some of the on car testers vary a lot in the readings - I've had them off by 45 lbs. when checking. They should be used for reference, and the spring should be checked with a calibrated spring tester to be absolutely sure of what you have.
Phil Molski
PMR Performance
S/C 1623
