Old 06-24-2019, 06:36 PM   #1
Billy Nees
Liked 7,682 Times in 1,730 Posts
Default Re: H-I-J '76 Nova re-fit.
Originally Posted by Nmbr1GMfan View Post
Not much done today, only the lifter bores grooved.
Why????????????????????????????
Billy Nees 1188 STK, SS
Old 06-24-2019, 07:17 PM   #2
HP HUNTER
Liked 372 Times in 129 Posts
LOL ahhhhhhhh
I can only say we go to great lengths to control oil leaks in the engine, and 16 lifter bores is definitely one of the places were looking to control.
Old 06-24-2019, 08:25 PM   #3
Nmbr1GMfan
Liked 1,954 Times in 491 Posts
Because I don't think the cam will live with 400+lb of spring pressure and no help.
Todd Greene
Old 06-24-2019, 08:48 PM   #4
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I’m glad I was not the first one to say WHY ?
Geez.
I built a low buck 350 for my buddy when he first started racing.
Cast HyperE pistons, cast crank, stock rods, flat tappet cam with .012” EDM’d lifters
Cam had .500+ lift I’m sure and 400lbs open pressure or dang near it.
It lived for years and went 10’s in a 2800-2900 lb Camaro running brackets and S/ST and the engine got sold running minus top end ....
Rich Biebel
S/C 1479
Stock 147R
Old 06-24-2019, 09:15 PM   #5
Nmbr1GMfan
Geez.
This makes no sense to me. You did the same thing only with the EDM lifter.
Todd Greene
Old 06-25-2019, 06:36 AM   #6
Glenn Briglio
Glenn Briglio's Avatar
Liked 969 Times in 307 Posts
What size are those grooves? Lifters have edm holes? Didn't you have an oiling problem already?
Old 06-25-2019, 06:51 AM   #7
Rich Biebel
Cutting grooves in the lifter bores can’t be undone.
Using the EDM hole lifters is an option and can be changed.
Some Stocker racers use Schubecks or Trend lifters and run tons of spring pressure.
The engine I built was low buck and the lifters were cheap.
It had good oil pressure and never hurt the bottom end
You could have used the edm lifters with no grooves and if that worked you were good. If it didn’t you could step up to better lifters. No grooves to complicate the build.
Rich Biebel
S/C 1479
Stock 147R
Old 06-25-2019, 09:32 AM   #8
Nmbr1GMfan
I have 4 sets of lifters, I tried EDM lifters and didn't like them. My preference is the groved block with non EDMs. I know not everything I'm doing or have done will be popular, and I'm ok with that. In my opinion there will never be advancement if we all do the same thing. I could have called any engine builder and had one built, I could have just paid 50k for a sorted out car, not my style. I appreciate all the help and advice, but sometimes I just gotta be me.
Todd Greene
Old 06-25-2019, 10:23 AM   #9
Nmbr1GMfan
Grooves are .006, no edm holes in the lifter. This engine ran fine for years with grooved lifter bores (as have others), current oiling issues are not related to this.
Todd Greene
Old 06-25-2019, 02:04 PM   #10
Liked 10,680 Times in 2,222 Posts
The groves look wider than the thickness of two hairs.
