Old 06-13-2019, 08:24 AM   #1
Liked 11,012 Times in 2,263 Posts
Default Re: Dumbo The Flying Elephant
All new parts engines need to have a bolt kit. Finding all the correct size, length, grade, and type has been a real treasure hunt. Dowels and O rings can be elusive. You can't afford to buy each bolt from the dealer. A valve cover bolt is $5.00 X 10 bolts per cover X 2 covers = $ 100. Solution for me is going to the local salvage yard and harvesting a lot of used parts. Billy will be so proud of me.
Old 06-14-2019, 08:20 PM   #2
Today has been a bad day, I feel like I was a tackling dummy.
Old 06-14-2019, 09:08 PM   #3
Nmbr1GMfan
A bit pricey but ARP makes accessory bolt kits. ARP 540-9801
Todd Greene
Old 06-17-2019, 02:28 PM   #4
If you need a small piece of shim stock to shim something and you live in the middle of nowhere or all the stores are closed. Open a few can goods and use the tops. I found them to .005'' to .012'' thick. This weekend it was Charlie The Tuna to the rescue, .007'' was perfect
Old 06-18-2019, 08:07 PM   #5
Another bad day in the trenches. Me and my old man wisdom wasted most of the day. All I had to do was degree the cam. What a comedy of errors, its going to be a difficult time facing myself in the mirror when I shave in the morning. Billy would not be proud.
After rubbing my head and patting my tummy I got'er done. Or did pat my head and rub my tummy? Who Knows
Got to go supper is ready. Saved by the dinner bell!
Old 06-18-2019, 08:40 PM   #6
Nmbr1GMfan
The bad days make the good ones that much sweeter!
Todd Greene
Old 06-20-2019, 09:05 PM   #7
Assuming , you know what that does, we have good piston to valve clearance. I will check piston to valve clearance at all of the planned cam centerline pulls. It will be fun to see where power and torque moves withe the changes. I should be able install the rest of the pistons and rods tomorrow
Old 06-21-2019, 12:16 AM   #8
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
It is tough getting it all to fit.
