Old 05-31-2019, 02:22 PM   #1
FED 387
Liked 333 Times in 180 Posts
Default Re: Fuel in intake
is the base plate or carb body warped???
Old 05-31-2019, 02:44 PM   #2
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
might be on to something, base of carb body is warped .011", top of base plate is .002"
I think I'll find some socket head screws to replace the Phillips head ones.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 05-31-2019, 05:44 PM   #3
GallopinGhost
Well I made some progress. The screws are #12, so I didn't have any of those, so I tightened up the base plate best I could and ran it. The last few times I've run this engine,the vacuum floats from 8-12 in. with the rpm tracking the the vacuum, acted the same this time. Took off the carb and there was still fuel in the intake, maybe a little less. I took the carb base plate off and the base, body, and gasket were pretty much dry. Previously they were soaking wet. Far from a slam dunk, but it's worth pursuing. I think I will try to re-surface the body and get a new gasket.
Brian Carpenter
Stock 1358
Old 06-07-2019, 08:43 AM   #4
GallopinGhost
Ok, I have finally found the real issue here. I did end up re-surfacing the bottom of the body and that is sealed up well. My original thought was to take out the power valve, I never tried that. So after looking at the baseplate, a lightbulb flickered on. First picture shows how I originally had it put together, second one is the fix.
ID:	50097   Click image for larger version
Brian Carpenter
Stock 1358
Old 06-07-2019, 09:52 AM   #5
Bobby DiDomenico
Liked 101 Times in 52 Posts
So changing from a 4 hole to a open plenum manifold gasket solved your issue?
Old 06-07-2019, 10:11 AM   #6
GallopinGhost
It made a huge difference in the idle. from what I see, the first gasket blocked the source of manifold vacuum that feeds the PV. I think the PV was opening during idle. At least that is my new theory. Spark plugs are now dry as well.
Brian Carpenter
Stock 1358
Old 06-08-2019, 10:28 AM   #7
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: Fuel in intake
Make sure you have some sort of 4 hole gasket or something else, like a 4 hole thin spacer, to keep a base plate to bowl screw from getting loose and backing out and falling into the engine through the intake! Holleys do that.Could save you an engine.
