Liked 10,714 Times in 2,230 Posts
Fellow racer Jeff Mc Adoo and crew did a good job on matching 10 year old paint. The service was really fast.
Thanks. Patsy will post pictures. |
Liked 101 Times in 52 Posts
Looking forward to seeing you out with the finished product Larry. Good luck!
Car, dog, son!
Liked 370 Times in 101 Posts
Looks great Larry !
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" |
Last two days I got nothing done on the car. Computer and phone issues at work. I spent time getting prepared to go to the FAST class next week. Had to get new battery for laptop. Making tooling today to get accurate measurement of installed height.of springs. Most of the 440 stuff wont work on the Gen III. I think it will be a challenge to check piston to valve clearance, I will be making stuff for that.
Time to go to work Last edited by Larry Hill; 04-28-2019 at 07:47 AM. |
Got my stuff made so I can check intake installed height. Height on one head only varied .007'' on the intake's, and changing valves position had zero effect. Could not check Ex valve height the mic would not collapse enough to get both keepers installed. Pac has a tool to fix that.
I did find a math problem. Taking the installed height, subtracting spring seat thickness, subtracting valve lift less lash and then compare to coil bind height. Much to my surprise the intake rocker if installed with the parts I have was going to try shove the spring down below the surface of the head .150''. That would make anyone have a bad day. Wiring the car this week. Back to work |
Liked 801 Times in 338 Posts
Thanks for sharing this will us Larry, I have enjoyed following your build.
