Old 03-26-2019, 08:02 AM   #23
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
Default Re: Master Cutoff Switch
Originally Posted by J&S Racing View Post
I’ve decided to run a switch even though I don’t plan on putting a battery in the truck just yet.
My question is about the wire from the alternator, can it run to the battery or does it need to be run to the switch?
Your alternator wire and battery cable should be on the same post on the switch. The other post on the switch will run the cable to your starter solenoid.
Jon Sarrett
Stock 3779
Jon Sarrett is offline   Reply With Quote
