Liked 920 Times in 259 Posts
Rulebook states "push" must be the off action on a push-pull type mechanism. And most of the levers on switches I'm aware of go CCW to turn off if it's mounted that way. Also states it must be marked.
I'm a fan of having some type of secondary cable or other way of operating the master from the driver's seat, for both safety and convenience. |
Liked 10,714 Times in 2,230 Posts
I have one in the car next to me that kills everything, just in case!
#3 | |
Liked 237 Times in 126 Posts
Ditto.
Liked 1,877 Times in 577 Posts
This Might be part of the problem, you get in an accident, shut your power off, first guy there thinks he’s turning it off and has turned it back on...
It should also be mandatory if you have one inside the car it moves the lever outside the car also, which I’m sure most people already do
The disconnect inside the car will not be affected by the outside disconnect being in the on position. The outside disconnect feeds the inside disconnect.
w |
#6 | |
Liked 704 Times in 281 Posts
If I have battery in stock location and add a second battery in back do I need a master cut off switch?
I think I don't but asking as I need to add a battery. |
#8 | |
Check the current class rules for your car. My guess is yes. Battery in trunk = rear deck mount cut off.
#9 | |
Liked 62 Times in 29 Posts
Now, back to the battery location issue. I have a 2008 Buick Lucerne, stock battery location is under the rear seat. My 2015 Camaro has the battery in the trunk, from the factory, so do the newer Vettes. These batteries are no relocated, wonder when the NHRA will start looking at these vehicles and making people put a switch in the rear of the car. And what about those electric vehicles............ |
Liked 520 Times in 132 Posts
Travis, I’m guilty of not having mine labeled. Thanks for the reminder, I will address it.
