Old 02-11-2019, 12:21 AM   #1
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Bellhousing alignment
Half is correct. You are in good shape. If you can get it tighter that would be better. Video is from Summit Tech.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 02-11-2019, 07:48 AM   #2
J&S Racing
Liked 327 Times in 87 Posts
Thanks Sean!!
Think this is about as close as I can get. Original dial reading was 48 half being 24 so I went with the .021 dowels getting me within .003 best case...
Old 02-11-2019, 11:23 AM   #3
Sean Marconette
Anytime!!! Hope to see some time slips from you this season.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 02-11-2019, 12:27 PM   #4
FED 387
Liked 333 Times in 180 Posts
.003 is damn close--- unless you futz around all day trying to get closer--then you might throw the other reading off if you finally do get it where you want it-- might also be burrs on the inside of the bell housing opening causing the gauge to read what it's readingFED 387
Old 02-11-2019, 03:37 PM   #5
Jim Caughlin
Liked 805 Times in 245 Posts
Interesting that no one is talking about parallel alignment which I have often found to be off by a mile. The video doesn't mention it either. Don't waste your time doing one unless you do both.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 02-11-2019, 04:05 PM   #6
J&S Racing
Jim Caughlin
SS 6019
I did check the parallel and was .001 out. This is after the spacer that wasn’t true and removing the powder coating on the engine and trans mounting surfaces.
Old 02-12-2019, 02:41 PM   #7
Run to Rund
Liked 54 Times in 27 Posts
I would play some more, such as moving .004 vertically and slightly to the side. I was able after some tries to get within .001" out after starting somewhere near where you are now. Be sure you tighten the mounting bolts starting at the bottom ones which are closest to being in line with the crank centerline.
