Liked 800 Times in 237 Posts
Pull the pan when the engine is still hot/warm and you won't see that. High zinc oils (over 1,000 ppm) will precipitate additives when the oil is cold. -Al
"That'll never work....." Last edited by Alan Nyhus; 01-19-2019 at 08:55 PM. |
Liked 665 Times in 187 Posts
So 5-8 hp from 10w30 to no oil ! Is it really worth any hp, from 10w30 to 0w5 LOL .we all do it ,but.......
5664 GHI/SA 1985 CAMARO RED H/SA --- FOR SALE 1985 CAMARO BLUE I/SA --- SALE PENDING ON BLUE CAMARO! Last edited by TOSTO RACING; 01-19-2019 at 08:53 PM. |
Liked 239 Times in 114 Posts
Oil helps the rings seal , without any maybe you would lose power from that and offset the gains from low oil pressure .
Liked 427 Times in 97 Posts
Looking for Opinions / Experiences on the differences between using Valvoline VR 10w-30 Synthetic-Blend vs Valvoline VR 10w-30 "Full Synthetic" motor oil?
Specifically with respect to ring wear? |
Liked 2,013 Times in 604 Posts
I had really good luck with the full synthetic Valvoline racing oil. Cant seem to find it anymore at the local parts stores.
Mike Pearson 2485 SS |
Liked 316 Times in 67 Posts
I've been really happy with JR-1
You may want to look at Reher-Morrision tech tips on oil and filters, oit of 100 tips they are toward the end (95 & up as I recall) Filter tip very interesting One thing they told me was to try Bad *** oil, I believe the originator of the early good Royal Purple. FWIW |
#7 | |
Liked 7 Times in 6 Posts
The question that I can't seem to get a decent answer to is why so many racers use multi weight oil instead of straight weight. |
May I ask the part number of the Valvoline oil you refer to?
I have used the VV850 in the past but they no longer offer it. I believe they changed the formulation. Do you use an additive with the oil? ______________________________________ Andy Stone A/S 1102 SS/C 1112 |
The oil I used is straight 30 racing oil. It used to be commonly called VV223 but the Valvoline part number is 822401. Scroll down a little to find Valvoline's conventional oil part numbers, https://www.valvoline.com/our-produc...vr1-racing-oil
I don't use any oil additives. |
Liked 759 Times in 379 Posts
don't use either.
Been running Mobil 1 Synthetic 10w-30 in my race engines for nearly 3 decades. This past season switched to Lucas Synthetic. Have a case of Maxima Synthetic that I will run this season. |
