Liked 12 Times in 3 Posts
1 Set new 1.650 titanium valve springs ($1000 new) - $350
2 Carbon Hoods for Chevrolet Cobalt with Carbon Hood-Scoops - $800 / each 15 sets aluminum SBC connecting rods 5.380 – 5.580 (15 – 40 runs per set) - $200 set 10 sets used great condition Casidium coated piston pins .866 - .927 many lengths available - $100 set 15 sets used Titanium valves different lengths and head diameter. Perfect condition - $200 set of 8 8 sets used Titanium Victory retainers 10 degree for 1.500 spring size - $100 set of 16 10 sets used titanium Victory keepers 10 degree for beadlock valves 5/16 and 7mm - $50 set of 16 20 camshafts 50mm, 55mm, clamshell for SBC Wedge, SB-2 and Splayed valve engines. Call for specs. Autometer Sport-Comp Playback Tach - $175 Book carb: 750 cfm for comp eliminator - make offer Book carb: 850 cfm for comp eliminator - make offer Jesel SBC .875 Drop in lifters SB-2 perfect shape - $500 MSD Front Drive Distributor complete - $375 FOR AURORA BLOCK MSD chips 3000 – 10,600 RPM - $5.00 each Simpson 5-point harness out of date SFI perfect shape - $100 set Simpson coats, pants, neck collars (used) - make offer 9" Ford Richmond lightened gear sets: 5.28, 5.67, 6.33 - $200 each 9.5" 5.83 Ford Gleason lightened, coated and cryoed gear set - $800 / SOLD BRAKES: · 4 – 4 Piston STRANGE Front & Rear aluminum brake system with calipers, rotors, hubs and brackets B4154C - $1000 · Mark Williams front brakes, hubs (ceramic), calipers, pads, for Cobalt; used - $600 · Lamb rear brake system with, hats, rotors, pads; like new - $600 COMPUTER SYSTEMS: · RPM Performance Products DL10 Computer with wire harness, sensors, and Dayton WEGO lllD System - $700 · Tons of Racepak parts and accessories (Collars, pickups, transducers, sensors, Cables, etc. Call for pricing CONVERTERS: · 2 - 7” A-1 / Schneider Steel Comp Eliminator Converters - $600 each / SOLD · 2 - 9” ATI Stock Eliminator Converters - $400 each / 1 SOLD TRANSMISSIONS: All fresh and can make many gear ratio combinations: · 1 Pro Trans / Chrysler case with GM adapter with all light weight and billet parts 2:25 / 1:51 - $4400 · 1 Pro Trans / Chrysler case with GM adapter with all light weight and billet parts. 2:32 / 1:51 - $4400 / SOLD · 1 Pro Trans / Chrysler case with GM adapter with all light weight and billet parts. 2:45/ 1:51 with Griner Valve Body - $4800 · 1 Metric 200 Transmission Automatic 1,2 shift with external adjustment – all aluminum and billet parts throughout 2:92, just updated to 1,2 shift with only 12 runs on it - $3000 · 1 Metric 200 Transmission Automatic 1,2 shift with external adjustment – aluminum drums 2:75, just updated to 1,2 shift with 0 runs on it - $2400 / SOLD TIRES: · Hoosiers BIAS 17.0 / 36.0 – 16 #C2055 ; 1 run - $500 · Mickey Thompson Drag Slick 14.5 / 32.0 – 15 #30751 ; 1 run - $450 · Mickey Thompson 32.0 / 14.0R – 15 #11808 ; used - $100 · Mickey Thompson 33.0 / 14.5R – 15 ; used - $100 · Goodyear Radials 30.0 / 9.0 – 15 ; used - $100 · Hoosier Drag Slick 9.0 / 30.0R – 15 #18212 ; NEW - $400 FRONT TIRES: · 2 sets of Mickey Thompson 25.0 / 4.5 – 15; great condition - $100 · 1 set of Moroso Drag Special 5.50 – 15 4PR; NEW - $125 · 2 sets of Hoosier Drag Fronts 28.0 / 4.5 – 15; NEW - $125 SOLD Jeff Lane Hancock and Lane Racing 206-818-1804 hancockandlane@yahoo.com Last edited by Jeff Lane; 11-21-2018 at 12:29 PM. Reason: Adding SOLD items to list |
Liked 969 Times in 307 Posts
Pm sent
Liked 53 Times in 17 Posts
PM sent
Liked 19 Times in 17 Posts
PM sent.
Liked 20 Times in 12 Posts
PM Sent
