#1 | |
Liked 1,954 Times in 491 Posts
http://www.blackmagicclutches.com/nexgenclutch.html We need to be over a second under here at home so Indy is no problem. And yes, the valve covers and the rims will be dealt with, more on that later.
Todd Greene |
#2 | |
Liked 965 Times in 306 Posts
Glenn, The current SLR (starting line ratio) is 15.83 3.08 first gear and 5.14 rear gear, 3300lbs and 400ish hp would be an SLR of 18. So if it will spin harder in the lights I could go with a 5.38 gear with a 3.19 first and be at 17.16 SLR. May be worth a litttle E.T. I think the lowest first ratio I can get is a 3.28, the other trans ratios would fall in line based on dyno sheets.
Todd Greene |
Borrowed a set of Weld 15x10 wheels to see if they fit, tire was wrong 28/10.5x15 but they fit pretty well I think, tight but the 10"ers fit. Compared to what I think are 15x8 wheel and a 30/9x15. Going with M/T 29.5/9.0x15 tire and a 10" rim I guess.
Todd Greene |
#5 | |
Liked 117 Times in 50 Posts
Are you going to be running lightweight radials?
Eventually. Starting with M/T bias to test a clutch theory, then we're going to test the radial.
Todd Greene |
#8 | |
Just got to say thanks for all your posting , My #1 thread anywhere ! Todd once again thanks..... ![]()
Old Nick in Tucson! Hahaha |
#9 | |
Todd Greene |
