#1 | |
Liked 98 Times in 23 Posts
Last time I checked this was the Stock/Super Stock section of the forum where fuels like C14+ and SR18 most likely are not primarily used so I cant speak to these products....I can tell you we've run VP C11, C12, C25, Sunoco Blue, Purple, Maximal and Surge and they all perform well and pass tech if handled appropriately. So to your answer your last question, for most stock eliminator engines the answer is not one bit.
Dave Ficacci 1013 STK 1170 SS Last edited by Dave Ficacci; 10-25-2018 at 10:11 PM. |
Liked 759 Times in 379 Posts
Dave Ficacci...KNOWS!
Seems to work pretty good in my Super Comp car too. ![]() |
Liked 62 Times in 29 Posts
It's a shame that Sunoco did nothing for the OP. Terrible way to handle business.
I have used VP C-12, C-14, their new fuel called VP Blue, Sunoco Blue and Red (Supreme and Maximal) in my car, they all run exactly the same. Been using Sunoco Purple in my slower car, no problems. Since I no longer Class Race, I am free to use whatever fuel I want to. I try to use Sunoco due to cost. Not all tracks have it, so I have to use VP from time to time. No problem, just more $$$$. The OP got screwed, he will never use Sunoco again, and I don't blame him. |
Liked 1,001 Times in 276 Posts
If anyone has questions or issues on Sunoco Fuels for Stock and Super stock in Div1, you need to call Jason at Insinger Fuels, He will be happy to help you any way he can.
Duane Hoven 1342 SS/GT |
My post was concerning people who posted that they failed fuel check. Jason will answer questions from anyone who has concerns or questions regarding Sunoco fuels for any class. Sorry I didn't clarify that.. Jason is a great guy and went out of his way to try to help Ryan Horensky when Maple Grove ran out of Surge at the Dutch Classic.
you didn't state that in your first reply. Further there are only 2 replies claiming they had issue passing fuel check and 3 replies stating they never had an issue with fuel check even when using fuel that was months old.
The reason I say the OP got screwed is that he never got a phone call back about the mistake.
I don't know if his fuel got pumped from a drum, or from a pump. Easy to see what they are doing at a pump. Not easy to see what they are doing from a drum. When you get fuel at Cecil, it is out of a drum, and for the most part you can't see what the label on the drum says, so you are assuming they are pumping the right fuel for you. Never had a mix-up there. Atco no longer pumps from a pump, no more Sunoco there, so buying a 5 gallon pail is simple, but expensive. Numidia pumps Sunonco out of the pump, CHEAP!, and easy to see what you are getting from them. |
#8 | |
Surely you aren't implying that Insinger Fuels wouldn't handle questions or issues any different for any racer regardless of class running their fuels.
I'm sure it was an honest mistake, pumped from the wrong drum as was mine. The OP like myself didn't catch it as he was pouring. That's on him as it was on me. Of course all racers should be checking their fuel before/as they pour it. Last edited by 1320racer; 10-27-2018 at 01:53 PM. |
