#23 |
Liked 310 Times in 174 Posts
There are two types of ballast to consider here. Permanent and removable. If you need to add more than 100 lbs total, then any weight other than that 100 lbs is considered permanent and the nuts are to be welded. Now you can use a box or bolts to secure the removable ballast, up to a 100 lbs.
