Old 10-11-2018, 06:18 PM   #21
Liked 5,121 Times in 1,952 Posts
Default Re: Weight box options?
Originally Posted by Hacksaw View Post
My rule book says: Removable weight must be securely mounted to the frame or frame structure by a minimum of two 1/2" diameter steel bolts per 100 lbs, or one 3/8" steel bolt per 5 lbs, all other weight bars, pucks, etc. must use 1/2" diameter SAE grade 8 bolts for attachment. Every Comp car or Pro Stocker has multiple places to bolt weight in and the nut has no weld.
Okay. Is that under general regs.? What does it say under S/SS?
Not a safety rule ,per se, but the idea is so that one couldn't easily pull out a bunch of weight for qualifying, etc. ,as I recall.
I realize that Comp cars put weight in all over the place, hose clamps and all, but we are discussing a Stock Eliminator car here.
