Old 09-18-2018, 04:04 PM   #1
Gary Federico
Talking Re: When do you shift
The transitions were smooth & that's what I looked for. But Keith has the inside stuff, he just doesn't share as well as play well with others on the 1320.
Gary Federico 1814 SST
Gary Federico is offline   Reply With Quote
Old 09-18-2018, 09:07 PM   #2
Superstreet29
Liked 4 Times in 4 Posts
Default Re: When do you shift
When I had my big motor in the car I could go on at .001 and shift at .20 and it was consistent. When I put the 467 back in, it seems to struggle sometimes shifting that early and the 60s aren’t consistent. The farther out I move the shift with this motor, the more consistent it seems to get. I think it knocks the breath out of this smaller motor when the air is bad. That’s why I was curious
Superstreet29 is offline   Reply With Quote
Old 09-18-2018, 10:55 PM   #3
Marc
Marc's Avatar
Liked 10 Times in 2 Posts
I messed around with shift points a bit last year and didn't notice any difference in consistency, but I did pick up some MPH shortening the shift from .65 to .30 (first timer is at .15). This was on my S/G TBird which is pretty light at 2465 w/driver and a 600" motor.
Marc is offline   Reply With Quote
Old 09-18-2018, 11:53 PM   #4
Superstreet29
Yep 2820 lbs is different is believe.
Old 09-22-2018, 09:02 AM   #5
Superstreet29
I think weight and HP makes a big difference in how early you can get away with shifting
Old 09-30-2018, 07:26 AM   #6
sst5167
sst5167's Avatar
Liked 17 Times in 9 Posts
I agree, but will also include hp and weight will determine how early you can turn the stop on.
Mike Boehner
SG 5169
sst5167 is offline   Reply With Quote
