Liked 482 Times in 159 Posts
When the rule was changed to allow solid lifters in Stock eliminator engines that were previously hydraulic equipped, did racers change cams or just install solid lifters ? What typically would they set valve lash at ? Not looking for top secret info just a general idea.
I have seen solid cams run in engines (not NHRA stockers) with hydraulic lifters that seemed to work "ok" but never the reverse procedure, |
Liked 240 Times in 112 Posts
Myself, I have just switched lifters. BUT, the pattern on the cam had to appear normal, I lubed the lifters just like installing a new cam. Put break in oil in the pan. Set lash and ran it for a Half hour at 2500. With a hydraulic cam there are no clearance ramps ground into it so I run lash tighter than usual. (under .010)
Dave Noll, EF/S ,?/SA 6526 Last edited by Dave Noll; 09-04-2018 at 05:34 PM. |
Liked 28 Times in 15 Posts
I installed solid lifters on hydraulic cam and was told by a well known cam grinder to set lash at .004 - works fine!
Liked 346 Times in 126 Posts
has anyone noticed a hp increase or a better et?
Liked 799 Times in 236 Posts
-With solids, you loose lift at the valve due to the lash under running conditions.
-With true hydraulics, the theoretical lash is '0'. In reality, there is some compression of the retained oil in the lifter. How much? .004? .006? More? less? And since the lift is checked at '0' lash..... ![]()
"That'll never work....." |
Liked 216 Times in 77 Posts
Going from non shimmed Hydraulic Roller Lifters to solid roller lifters. What would you expect to see as far as performance increase?
Liked 184 Times in 113 Posts
The way I see it...
Solid Lifters allowed an engine to spin tighter with the same Spring. Over the years (decades) Hydraulics improved with Short Travel Lifters and other modifications to get them to behave more like a Solid Lifter. Couple questions. Are Solid Lifters Lighter than Hydraulics? Do solids allow better ramp rates and duration? Is there any improvement to valvetrain control? |
Liked 5,125 Times in 1,953 Posts
Minus 4 thou lift not a big issue to me .Probably lose that much on the other side with hydraulics.
Last year, guys were talking .010. Any more real world, hands on reports about lash from last season?
I am in the process of switching from hydraulics to solids on the same cam (originally ground by crane who was of little help to me) (maybe I talked to the wrong guy). Called Bullet, they were very very helpful and instructed me to swap to an "EDM" lifter @ .008 hot. I'm going to tighten the lash from there on the dyno to see if there's any + or - results. I hope there is a peformance improvement for me with lifters, pushrods, rockers and properly setup springs.
Todd Greene |
Liked 88 Times in 28 Posts
Treating your cam , Nitride or Cryo is worth looking into.
