Old 08-14-2018, 11:00 AM   #1
Jim Caughlin
Liked 805 Times in 245 Posts
Default Re: Lighter wheels = any E.T reduction?
I have done extensive back to back testing with lighter wheels, lighter drive shafts, gun drilled axles, alum spools and any other low weight rotating part that I can find and have had zero improvement. As my car is very low HP, I would think that if any car would improve it would be mine. If I was starting over with a new car, I would still buy all of these lightweight parts but if you are on a budget, don't waste your money.
Jim Caughlin
SS/FS 6019
Jim Caughlin is offline   Reply With Quote
Old 08-14-2018, 11:40 AM   #2
nhramnl
Liked 358 Times in 83 Posts
I tend to agree with Jim. Remember that most of the super-trick, gun-drilled, unobtanium stuff was designed for Pro Stock (and maybe Comp), where getting the entire car to a crazy light weight was the challenge. I honestly think that today, it's mostly for the coolness factor.
Old 08-14-2018, 12:53 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Interesting idea , but I don't agree with Jim . I believe the lightweight stuff does work for all weights of cars , but the faster the acceleration rate, the more important lower inertia parts are . Higher horsepower cars accelerate quicker , so for them its more important . Also the farther that lightweight part is from the engine the less effect it has on hp it takes to spin it up . Another point is a tire is only spun up from zero to maybe 1600 rpm in say 9 secs , a driveshaft from zero to 8000 rpm , and an engine spins up several times , depending on how many gears you have in the trans . So if I were to prioritize what things to concentrate on reducing mass just for pure acceleration it would be the engine , then the tires , followed by the wheels , and finally the driveshaft . There are other reasons for lightening up stuff like overall weight , ease of doing , or expense . If we all had unlimited funds , we would do all the above .
Old 08-14-2018, 01:18 PM   #4
Bobby DiDomenico
Liked 101 Times in 52 Posts
Originally Posted by ss3011 View Post
"Interesting idea , but I don't agree with Jim." "If we all had unlimited funds , we would do all the above .
Yep, lighter, stronger always better! Return on investment in this case? Like you I'm spending that $600 or more on engine/trans.
I wouldn't spend it on slightly lighter than light wheels. I still agree with Jim, for the results save the money if you are on a budget.
Old 08-14-2018, 01:34 PM   #5
FED 387
Liked 333 Times in 180 Posts
You would be surprised at how many revs a tire actually turns from the time it leaves the starting line until it goes a 1/4 mile. Actually About 150 to maybe 175 times depending on if you have smaller or larger diameter tires. The same with engine maybe 1200 actual revolutions on an engine turning 7200 rpm in a 10.5 second run
Old 08-16-2018, 05:37 PM   #6
voltdr
Liked 100 Times in 51 Posts
Because we can't test in a "vacuum", our test results are subject to interpretation based on any differences in track surface, track temps, wind direction changes, and any other number of variables. I do believe that if you apply all of the things that are supposed to be better, then it will be better. You just may or may not see the results immediately.
It's the same in my electrical business, I can guarantee that you will use less electricity by switching to a more efficient electric motor or LED lights, but you might not see a difference in your electric bill due to differences in running time of all of the components are different each month.
Dan
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 08-14-2018, 03:04 PM   #7
nhramnl
I think we're saying the same thing, just differently. As another poster suggested, if I'm choosing between gun-drilled, 40-spline axles, an aluminum spool and a lightened ring and pinion, I would probably save the money and put it in the engine. Reducing unsprung mass does allow quicker acceleration of the component in question, but the question becomes "At what price for what gain?"
Old 08-14-2018, 06:30 PM   #8
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
I`d have to agree with Jim on this as well. I`ve done back to back runs with steel wheels and Centerlines with the same size tire and saw no noticeable improvement on a V/SA Buick Skyhawk or Skylark.
Lane Weber
Old 08-14-2018, 07:19 PM   #9
Ed Wright
Ed Wright's Avatar
I went from four Stock steel wheels to four light aluminum wheels on my '56 Chevy Jr Stocker, and was disappointed to find zero change in ET or MPH.
Same results from going to an aluminum spool, lightened ring gear & drilled axles on my C/MP '69 Camaro a few years later. I have wasted a lot (to me) of money testing "trick" parts over the years.
Ed Wright 4156 SS/JA
Old 08-14-2018, 08:33 PM   #10
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
The further away from the centerline of rotation the greater benefit of rotating weight reduction..
Remove 1 pound of rotating weight from the OD of the flywheel vs. a 1 pound reduction from gun drilled axles.....
It's called moment of inertia.
Just sayin'
Bob Mulry 7516 STK
A & M Motorsports
