Old 07-23-2018, 10:15 PM   #1
b.guggenmos
b.guggenmos's Avatar
Liked 3 Times in 1 Post
Default Re: In search of Jerico Parts
I received a long response from Jerico I shared with Rory McNeil this weekend at a local stick race. Long story short Jerico said they will not produce parts costing hundreds of thousands of dollars and then be stuck with them or not make any money id they do sell.
Talking with Rory this weekend we know of far more people running DR4's that will need parts at some point than DR4-4's. I can't think that running a batch of mainshafts for stock would be a huge investment for Jerico to keep their customers existing transmissions going.
I purchased a new DR4-4 last year. I looked at GForce but in my car it would have required some serious work to get the shifter back far enough. The Jerico is on the very last holes on the extension housing but is perfect. I did send my Long shifter to have stops added and converted to a pistol grip.
Maybe if enough people contact Jerico they will rethink the decision to drop support of the DR4?
b.guggenmos is offline   Reply With Quote
Old 07-24-2018, 06:14 PM   #2
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
so, what goes bad with the mainshaft?
maybe I should rephrase that....what HAS been happening to the main shafts?
if I do sell this trans (most likely), I don't want to stick somebody with junk parts
Old 07-25-2018, 08:27 AM   #3
terry1
Liked 24 Times in 13 Posts
Smile Re: In search of Jerico Parts
If, by main shaft, you mean input shaft, in the past I have broken
the nose of two input shafts.
After re-re-re alignment of the bell , no further problems.
I will also go to a bit longer pilot bushing.
Terry K
terry1 is offline   Reply With Quote
Old 07-25-2018, 08:34 AM   #4
Tom keedle
Tom keedle's Avatar
Terry K
everybody was talking main shaft, I assumed it wasn't the input shaft....
Old 07-25-2018, 09:57 PM   #5
b.guggenmos
Terry K
Rory broke a main shaft. Not the input shaft. Jerico may have input shafts? Chrysler 18 spline is popular as well as big Ford, small Ford... I did not need one when I talked them.
Old 07-25-2018, 02:21 PM   #6
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Too bad that you spoke to someone without a brain...
If they had one they could pre-sell them and manufacture a batch of parts to fit the needs of their customers...
They are just a short sighted company that is operating without a clue.
Maybe the next owner will get it????
Bob Mulry 7516 STK
A & M Motorsports
Old 07-25-2018, 05:59 PM   #7
terry1
I would be in for a spare input shaft if they would consider doing a
run of selected DR4 parts!!!
Terry K
Old 07-26-2018, 12:38 PM   #8
Jim Caughlin
Liked 806 Times in 246 Posts
Hundreds of thousands of dollars to make replacement main shafts that they already have designed and just need to do a production run on? We have a lot of CNC machine tools at my work and I can tell you $100,000 goes a long way when it comes to CNC machining. In addition, we regularly make one off replacement parts for out of date machinery that we built all the way back to the 70's, it's called 'customer service'.
Jim Caughlin
SS6019
Jim Caughlin is offline   Reply With Quote
Old 07-30-2018, 10:39 AM   #9
terry1
Jerico still has some DR4 input shafts, 26 spline(Chev app), as well as
the Billet retainer(Chev 90mm), this is the sleeve that the
release bearing rides on.
I dealt with Catherine, great to work with, as well as Scott!!!!
Terry K
Old 10-28-2018, 07:22 PM   #10
b.guggenmos
Jerico is still sticking to the no new parts for an old transmission philosophy of f how to run a business or how to abandon you customers! The list of people needing main shafts seems to be growing. I found an article from 2008 with Jerry Hemmingson telling how easy it is to make a main shaft with his the new machine. Kind of ironic now!
http://toolingandproduction.com/feat...08_tranny.aspx
