#1 | |
Liked 117 Times in 50 Posts
And I'd run the numbers before purchasing the 4.09 ring & pinion- the power peak on the Ecoboost engine is only at 5,500 rpm. First gear is so deep, that you'd have a pretty steep launch ratio even with the stock gearing. And turbo engines tend to be more tolerant of taller gearing anyway. |
Liked 120 Times in 42 Posts
2015 Ford Mustang Ecoboost Auto on craigslist Portland Oregon for $17,500 if interested?
#3 | |
Liked 128 Times in 50 Posts
Bobby Lundholm 3516 G/SA |
#4 | |
The 6R80 transmission has a 4.17 first gear. If you combine that with a 4.09 ring & pinion, that would give you a launch ratio equivalent to running a C4 with a 6.50 rear gear. I just don't think that's necessary for an engine that makes almost all of it's torque by about 2,500 rpm. The calculations I ran, had the car going through in 4th gear, which is 1.14. 5th gear is .87, and 6th gear is .69. This engine makes so much torque and has such a wide powerband, with a horsepower peak at a relatively low 5,500 rpm, I don't think it would need to use that many gears to get down the quarter mile efficiently. With a 30" tire, a 3.73 ring & pinion, and a 1.14 4th gear, the car would do just about 115 mph at 5,500 rpm through the lights. With a 28" tire and the stock Performance Package 3.55 rear end gears, it would do 113 mph at 5,500 rpm in 4th. With a 28" tire and the stock non Performance Package 3.31 rear end gears, it would do about 115 mph at about 5,300 rpm in 4th. I'd be tempted to try it with a 28" tire and the stock gearing. |
Earlier in this thread, there is a video of a stock-turbo stock-engine street Mustang Ecoboost running an 11.03 at 122 mph, on the stock axles.
If you can get a K/SA four-cylinder Mustang into the 10s, then yes, the rulebook will require you to run aftermarket axles. But until that point, I think that $2,000 would be better spent elsewhere, in my humble opinion. ![]() |
#6 | |
