Old 06-24-2018, 08:51 AM   #1
Billy Nees
Liked 7,780 Times in 1,743 Posts
Default Re: flash rpm question
I'm not sure that I'm understanding your question.
BUT, if you have a combo that has a known "flash RPM" and you increase the torque and HP, your "flash RPM" should increase.
Billy Nees 1188 STK, SS
Old 06-24-2018, 09:55 AM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
K=R/square root of T
K is the constant Factor of the converter and will stay the same
T is torque
R is the stall speed
So by combining old torque equation and new torque equation , knowing K is constant
Rnew = Rold x (SqRt Tnew / SqRt Told)
Example
Rold = 5000 rpm
Told = 500 ft.lbs.
Tnew = 550 ft.lbs.
Rnew = 5000 x (sqrt 550 / sqrt 500)
Rnew = 5000 x (23.45 / 22.36)
Rnew = 5000 x (1.0488)
Rnew = 5244
So basically with this converter if you upped the torque by 50 ft.lbs , it would increase the stall from 5000 rpm to 5244 rpm .
Old 06-24-2018, 10:21 AM   #3
Billy Nees
^^^^^^^^^^and he would know!^^^^^^^^^^^^
Old 06-24-2018, 10:59 AM   #4
al wisniewski
Billy,I know it will increase,just trying to get a feel for what I will have and figuring a new convertor out.
al wisniewski is offline   Reply With Quote
Old 06-24-2018, 03:48 PM   #5
al wisniewski
SS3011,thanks for the formula!
Old 06-25-2018, 12:38 PM   #6
340Cuda
Liked 804 Times in 341 Posts
Do any converter manufactures show a "K" rating for their converters?
I only remember Mopar Performance doing that in the past.
Old 06-25-2018, 03:34 PM   #7
Ed Wright
Ed Wright's Avatar
T is torque
Example
Rold = 5000 rpm
Told = 500 ft.lbs.
Tnew = 550 ft.lbs.
Rnew = 5244
Very interesting. Thank you!
Ed Wright 4156 SS/JA
Old 06-25-2018, 04:16 PM   #8
FED 387
Liked 333 Times in 180 Posts
If k is the constant factor of the converter is that factor the same for all converters or does each converter have its own specific factor? How is the factor determined? Thanx very informative where did you obtain this formula? FED 387
Old 06-25-2018, 04:36 PM   #9
ss3011
ss3011's Avatar
The K factor is specific for each converter . We had a converter dyno that we would lock the output shaft (stall) and then input a specific torque , then we would measure the rpm . The formula K = R / sqrt T was developed from those tests . As long as the converter is not cavitating that formula will hold true .
If you have a transbrake and a dyno torque curve on your engine , you can determine the K factor of your converter . You would just engage the transbrake , go WOT (no two step) and measure the rpm your engine goes to . Then you can look up on your torque curve what engine torque you achieved at that RPM . Plug the numbers into the formula , to determine the K factor . This is a great way to determine the relative difference in looseness between different converters .
Old 06-25-2018, 05:47 PM   #10
Liked 10,756 Times in 2,236 Posts
Thanks Russ
