Old 06-21-2018, 07:59 PM   #1
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: 8.5 S Spring Posi
Not sure what thickness yours are but Dorman #81050 has one each of .150 and .155 thick. I believe the end play should be about .022-.025 max. Sometimes you need to juggle clip thickness to get it right. GM used to sell a package of 10 with five different thicknesses. -Al
P.S. You can also take out a clutch pack shim and shim the pinion gears a bit more.
"That'll never work....."
Old 06-22-2018, 12:31 AM   #2
Randy Schonscheck
Liked 2 Times in 2 Posts
Thanks Alan, My clips are in the .147 to .150 range. I'm going to see if I can hunt up some thinner ones or have some machined to thinner specs. I've run into silly problems in the past but this one takes the cake.
Randy Schonscheck is offline   Reply With Quote
Old 06-22-2018, 07:33 AM   #3
Alan Nyhus
You can also machine a flat on the cross shaft. -Al
Old 06-22-2018, 01:37 PM   #4
Tom Broome
Liked 88 Times in 43 Posts
Street car I hope. I'm with the others, clearance the cross shaft (do they still make the notched ones) or thinner clips.
Tom Broome is offline   Reply With Quote
