Liked 974 Times in 310 Posts
Racepak O2 sensor: Is there a replacement for the O2 sensor that comes with a clip to hold the two connectors together. Other than going back to Racepak.Actually just need the clip which I broke.
Liked 309 Times in 88 Posts
I ran into the same problem, old stand by zip ties was the cure.
Yeah that's what on it now................not happy with that
Usually the brand, and a number on the Old one. I found NAPA Auto Parts, if you find an experienced parts guy, can take that info and find you the same exact sensor. Not likely Racepak changed the connector on the sensor.
Ed Wright 4156 SS/JA |
Liked 20 Times in 16 Posts
Back when I swapped my FAST stand alone O2 setup for a Racepak unit, i'm pretty sure both used the same connectors, although I don't remember plugging each in to see.
Here's the O2 sensor... http://www.lsxtune.com/shop/product_...roducts_id/534 Here's it's mating connector... http://www.lsxtune.com/shop/product_...roducts_id/678 The whole mating pigtail... http://www.lsxtune.com/shop/product_...roducts_id/695 Grant |
Also, all Wideband sensors don't read the same. Learned that on my dyno. I bought a new one, and found it showed leaner air/fuel numbers than the old one. I ordered yet another, put my pickup on the dyno, and made 2 pulls, plugged in the new one, A/F went from 13.0-1 to 13.25-1. Put the old sensor back in, 13.0-1. Ordered yet another new sensor. Back to 13.0-1. Tagged the Lean sensor at ".25 Lean", and kept it for a spare. If I had a car in that was not as rich as I expected, I put the spare in to verify the sensor I was using was not indicating a false lean condition. Leaded fuel does degrade O2 sensors. I always keep a known good spare for my FAST system on my race car. If you buy a spare, I would back-to-back test them to verify they agree. That is why you cannot just tell a guy to tune his car for a given magic number A/F ratio. His sensor may not read just like yours. That's why we test, right? Mine does not make the best power at the same air/fuel ratio with all fuels, either.
Always something, right?
Ed I like how you say "if you can find an experienced parts guy" that in itself is hard to do these days!
#8 | |
Look for some gray hair. LOL
Number on sensor 258007018
Liked 880 Times in 311 Posts
Ed,
The part where all fuels don't make the best power at the same A/F ratio is missed by a lot of tuners. Same as the guys that tune with EGT #'s. I had to shake my head a few times when a customer told me it had to have a certain deg EGT's. If it didn't it wouldn't make power till it did. ![]()
Adger Smith (Former SS) |
