Old 04-28-2018, 11:04 PM   #1
Paradigm Shift
Liked 80 Times in 29 Posts
Default Re: Dodge HEMI Challenge - Indy
Don't overlook the venerable Ford Motor Company 4/30!
The Super Marauder was a force.
Paradigm Shift is offline   Reply With Quote
Old 04-30-2018, 07:29 AM   #2
nhramnl
Liked 358 Times in 83 Posts
[QUOTE=Spyphish;561942]
Originally Posted by nhramnl View Post
Beautiful engine! Is their shootout the day after the hemis?
If you look close, you will see that the chassis in which the engine is installed is a Camaro. The 427/435 was never available in anything but Corvette, so the owner of this Camaro either installed a complete 435 engine, or the 3X2 manifold and carb setup from a 435 engine. Chevy guys know that the 3X2 setup was available in either 400 or 435 HP versions, in the Corvette. Anybody remember what the difference was between the two engines?
Old 04-30-2018, 08:09 PM   #3
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Smile Re: Dodge HEMI Challenge - Indy
The 400 was a oval port hydralic cam engine. The 435 was a rectangle port with a solid cam.
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
Old 04-30-2018, 08:14 PM   #4
l88427
Liked 17 Times in 8 Posts
[QUOTE=nhramnl;562051]
427/400 had 10.25 compression cast pistons cast crankshaft,Hydraulic tappet camshaft and oval port closed chamber heads,427/435 Hp. had 11.5:1 compression forged pistons, forged steel crankshaft, Mechanical flat tappet camshaft and rectangular closed chamber heads,Tri power setup looks real sexy but a single Holley Dominator makes more power....
l88427 is offline   Reply With Quote
Old 04-30-2018, 09:35 PM   #5
Spyphish
Liked 679 Times in 180 Posts
Never fails..... Bowtie highjack. Bring 'em.....
