Old 02-06-2018, 08:46 AM   #1
nhramnl
Liked 358 Times in 83 Posts
Default Re: Cam&Lifter& valvelash?
I think Derek is right. If you put the lash at zero with a solid lifter, when things warm up and expand, you will either bend pushrods or hold the valves open. Lash exists to allow for the clearance change that occurs when things go from cold to hot.
Old 02-06-2018, 10:59 AM   #2
t.tosto
Liked 62 Times in 23 Posts
While on this subject, new to me is hyd. lifter combo, 255/350. With Shubeck hyd. lifters, what procedure is recommended to set valves with respect to preload. Always ran solid lifter B/B before, many thanks for any response, Tony Tosto.
t.tosto is offline   Reply With Quote
Old 02-06-2018, 04:34 PM   #3
jmantle
Liked 172 Times in 81 Posts
I've been running .006" cold with Shubecks. They tighten up .003/.004 hot so I still have some lash.
Jim Mantle V/SA 6632
jmantle is offline   Reply With Quote
