Old 02-06-2018, 04:41 AM   #2
D. Hake 4459
D. Hake 4459's Avatar
Liked 2 Times in 1 Post
Default Re: Cam&Lifter& valvelash?
When you zero lash the hydraulic lifters is there any travel left in the lifter or is that bottomed in the lifter? If there is travel left in the lifter, there is your lash. I would think if you zero lashed a solid lifter when everything heats up it would wind up holding the valves open a little. I may be thinking backwards, it is pretty late. Derek
Derek Hake 4459 H/SA 69' Roadrunner
D. Hake 4459 is offline   Reply With Quote
