Old 11-24-2017, 09:28 AM   #1
Tom Broome
Liked 88 Times in 43 Posts
Default Re: stocker gas line
Just curious, wondering (surely this has been tested) about the flow rate difference through a given size needle & seat assy (say a .125" or .150" dia orfice in the seat) with various i.d. fuel hoses, all much larger I.d. than the orfice in the needle & seat? A Quadrajet only has one, with a small float bowel for all four jets. I'm guessing the most difficult carb to keep full enough? Kinda seems like if the fuel line/hose I.d. was larger than that one orfice, a larger line would not help. Pretty interesting, thinking how a much larger line would alter the flow rate through the seat orfice.
I worked for an aftermarket manufacturer once upon a time and we did test some different configurations using an orifice attached to a flow meter.
We were attempting to qualify the differences between needle and seat area and fuel pressure with respect to fuel volume. We also tested differing configurations before and after the secondary regulator. It's been so long ago now that I don't recall the specifics of that test, but I do remember a fondness for bypass style systems. It seemed that the less total area that you flowed through needed a bypass to keep the secondary regulator functioning.
If the fuel system was primarily laminar flow like fuel injection, fuel line area and orifice area can be closer than a carbureted system. Since a carburetor is essentially a siphoning device, fuel flow through the boosters and calibration are affected by the level of fuel available in the bowl(s). When the needle(s) open the bowl needs to be refilled as rapidly and smoothly as possible.
If your using alcohol with a carburetor the pump essentially overcomes the regulators ability to control pressure at some engine RPM. The needle and seats are the restrictions but volume is increased with the excess pressure.
Tom Broome is offline   Reply With Quote
Old 11-24-2017, 03:05 PM   #2
Ed Wright
Ed Wright's Avatar
I can see the pressure increase, but not the very large fuel line id.
Back when I was running my old '56 Chevy, and NHRA killed Stock, and we had to move to Super Stock, keeping my fuel bowls full became an issue. Ran two Carter WCFBs, four .110" needles & seats. Those carbide could certainly use more bowl volume. .No wide band O2 sensors & data loggers back then. Most everybody fast knew how to read plugs. Suddenly could not cure lean high gear issues in SS mode. The best pumps I knew of at the time were Carter.
I tried two in series, which made for about 20 psi. That high fuel pressure was faster, but of course both carbs flooded at idle, and on the return road. I had to add a second toggle switch, tripped by the shifter for the second pump. Worth about 2 MPH. Don't remember the ET gain.
Already had one for the second set of points, to retard the timing in second & high gear. Changed to a double pole toggle, to retard the timing & turn on the second pump at the 1>2 shift with one switch. Go through the lights, lift the throttle, and flip that switch back. I was young. Probably forget to flip that switch now. LOL
Ed Wright 4156 SS/JA
