Old 11-22-2017, 12:56 PM   #5
Liked 5,121 Times in 1,952 Posts
Default Re: Testing Line Pressure TH-350
Originally Posted by brian schuetta View Post
Between the modulator and the servo?
Right side of TH350 case.
Rear port is main line pressure. You will see pressure here in all gears for most valve body configurations. Some race-only valve bodies may not have pressure at this port or the others
Middle port is 2nd gear pressure
Front port is third gear pressure
