Old 11-06-2017, 02:30 PM   #1
Jeff Niceswanger
Liked 1,072 Times in 379 Posts
Default Re: 83' Camaro Top Strut Mount.
If you go with OEM, I believe the Z-28's and IROC's had a bearing, where the cheaper models had a bushing ...
Jeff Niceswanger 3740 SS
Jeff Niceswanger is online now   Reply With Quote
Old 11-06-2017, 03:19 PM   #2
brian schuetta
Liked 28 Times in 15 Posts
Jeff, will check that out. I don't remember seeing that before but will check, have access to many examples. The ones I dug out of the shed have bushings. Will price new pieces also. Nice Kit shown there, maybe in the spring time.
brian schuetta is offline   Reply With Quote
Old 11-06-2017, 04:35 PM   #3
FED 387
Liked 336 Times in 183 Posts
look on eBay top strut mount plates lots of the with the bearing no bushing about $55-75 per pair---Fed 387
Old 11-08-2017, 10:30 PM   #4
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
We use RaceCraft on all the 82-92 Camaro that we install Santhuff Struts on. The work great.
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 11-09-2017, 11:24 AM   #5
brian schuetta
The Racecraft setup can be used with any strut right?
Old 11-09-2017, 08:07 PM   #6
Eman
Liked 133 Times in 76 Posts
I don't know if the aftermarket upper strut mounts are legal in stock or super stock as I'm just a bracket racer. I have had your exact problem and bought a nice set on ebay that work with factory struts and aftermarket replacements. They are all steel and can accept a coilover also. They have 2 sets of adjustments and give you more caster.
https://hotpart.com/product/camarofi...ucts-made-usa/
These are what I have.
Old 11-09-2017, 10:06 PM   #7
Tim H
Tim H's Avatar
Liked 485 Times in 160 Posts
Never say " just a bracket racer "... ha ha because that what most of these guys are once eliminations start , unless a heads up situation arises ...
