Old 09-13-2017, 12:21 AM   #21
David Lee
Liked 346 Times in 126 Posts
Default Re: S/SS Brake safety
Originally Posted by HandOverFist View Post
You can see it behind this M/C...
I am using the mopar 4 to 2 adapter, can i still use this?
Old 09-14-2017, 07:26 AM   #22
J&S Racing
Liked 319 Times in 82 Posts
Well this was good timing. Car just came back from the chassis shop and first order of business is brakes.
I will be using the mopar master with the 4 to 2 adapter like David and I'm wondering the same thing. Can the bickle piece be used with the adaptor or will a stop need to be made?
Old 09-14-2017, 03:46 PM   #23
Strawboss
Liked 2 Times in 2 Posts
We did this on a Camaro back in the late 80's. We bent a u shaped bracket about 1" wide thin metal with a hole in the center and placed it behind the MS and the push rod thru the hole. You had to slot the firewall to clear the bracket and drill holes to bolt on the MS bolts but this way there is no way for the rod to fall out. It is still that way today. This is cheap an easy to do.
Strawboss is offline   Reply With Quote
Old 09-14-2017, 07:42 PM   #24
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
So for the guys or gals that buy the Lamb brake conversion don't pass up the master cylinder option.
All the master cylinders come with the life saving bracket as well from Lamb.
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 09-14-2017, 09:00 PM   #25
Kevin Panzino
Kevin Panzino's Avatar
Liked 747 Times in 136 Posts
Yep, very big deal. I remember when this came up several years ago, someone wrecked from this and posted about it on here. I immediately went downstairs and 'enlisted' my young son who was far more flexible than me to go under there and check it out. No problem, the bolt and nut arrangement was already in place limiting the back travel of the pedal ('ol Joe Scott knew what he was doing )
Old 09-15-2017, 11:01 PM   #26
CMcAllister
Liked 920 Times in 259 Posts
I've seen a number of cars torn up over the years and some guys who were lucky to not get badly hurt. On anything I'm involved with I use a positive pushrod retainer of some sort at the master cylinder. In a pinch, I've used the strap across the back of the MC or I've made a piece similar to the Bickel piece out of thin wall tubing with an end cap and a flange to capture it under the MC. I also use some sort of a positive stop on the brake pedal. Plastic brake light switches are not very secure and are often missing. Also verify the hardware, clips, pins or whatever that attaches the rod to the pedal.
CMcAllister is online now   Reply With Quote
Old 09-16-2017, 12:14 PM   #27
Dave Gantz
Liked 251 Times in 125 Posts
Originally Posted by Andys dad View Post
Why isn't it mandatory like a seat belt or helmet?
It could be covered in the tech inspections.
Ron
This^^
Old 09-16-2017, 12:57 PM   #28
CMcAllister
Ron
Long ago when I did tech at a local track for a few years, it was not unusual for me to reach in and give the brake pedal a jerk up and then a push down on the Mopars. Kind of surprising that some folks are unaware of the issue and how to prevent it.
Old 09-17-2017, 10:38 PM   #29
Tom P
Liked 239 Times in 94 Posts
As a Ford guy this is quite a foreign problem. Every pushrod i've tried to remove from a master cylinder required tools and sometimes naughty words. The manual brake ones have a groove in the pushrod and a clip
Here's an aftermarket adjustable one that shows it.
http://www.cjponyparts.com/media/cat...161_1.1113.jpg
