Old 09-12-2017, 08:50 PM   #8
David Lee
Liked 346 Times in 126 Posts
Default Re: S/SS Brake safety
After seeing the result of Lou Centelazzo's unfortunate crash this past weekend , Id' like to remind my S/SS friends about something I find on all too many cars I see in my shop.
Many cars ,regardless of the type of master cyl. do not have a push rod retainer or a positive brake pedal stop to prevent the pushrod from disengaging the master cyl. .
Since many cars have had the brake light switch removed there is nothing to keep the pedal from disengaging the pushrod but a small rubber retainer .
A small bracket with a stop bolt in place of the brake switch will prevent this ,just be sure to keep a small amount of clearance between the stop and pedal.
Another method that works if you have the Mopar master cyl , which most cars have is the Jerry Bickel push rod retainer kit .
This retainer is simple and will work on almost any application ,and it's only about $70 .
i must be daft, can you explain where this goes. I am converting to a mopar mc as we speak and last thing I need is an unsafe brake system
