Old 09-12-2017, 03:51 PM   #1
Steve Polhill
Steve Polhill's Avatar
Liked 262 Times in 74 Posts
Default Re: S/SS Brake safety
On My Escort the Pedal is attached to the Master cyl Rod with a pin right from the factory.
Steve Polhill
3520 STOCK, COMP
Steve Polhill is offline   Reply With Quote
Old 09-12-2017, 04:22 PM   #2
Hacksaw
Liked 310 Times in 174 Posts
I went off the end at Martin about 10 years ago. Frightening to say the least. My fix was to form a "top hat" from heavy sheet metal flat bar with the two outer holes matching the master cyl mounting holes and a center clearance hole for the pushrod to go through. After a mockup, I marked the exact spot for a flat washer to get welded on the rod, on the cyl side of the "top hat" with a slight amount of clearance. Simple and works.
Old 09-12-2017, 04:50 PM   #3
Kevin J. McHugh
Thanks Tom, your advise is greatly appreciated!
Kevin J. McHugh is offline   Reply With Quote
