Old 09-01-2017, 11:50 AM   #1
junior barns
Liked 20 Times in 14 Posts
Default Re: Important if you run D-H/S or SA
Originally Posted by GTS340 View Post
Might want to check with Mr. Beach on the performance gain. I believe he still runs all cast iron. Maybe NHRA not adding these runs to their respective combination at Indy this year helped. Looks to me it was very competitive in D-F/SA and for those guys probably a blast. Well for the winner anyway.
Yea! And how fast will Mr. Beach going to go when he does change!!
junior barns is offline   Reply With Quote
Old 09-01-2017, 11:56 AM   #2
Greg Hill
Liked 279 Times in 68 Posts
He's already changed!
Greg Hill 4171 STK
Old 09-01-2017, 12:09 PM   #3
Bruce Noland
Liked 444 Times in 145 Posts
My vote for most impressive performance gain is Mitch in his Barracuda. Not sure if he runs the 340 with the intake in question. 1.16 under at Indy is very impressive.
Bruce Noland 1788 STK
Old 09-01-2017, 12:37 PM   #4
Rod Greene
Liked 242 Times in 81 Posts
It is a 383 rated at less HP than a 340.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Old 09-04-2017, 12:35 PM   #5
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
https://www.google.com/amp/www.hotro...flow-test/amp/ The testing in this article shows a lot better flow than the iron intake.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 09-04-2017, 01:02 PM   #6
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
It also shows the Edelbrock RPM averages 45 CFM less than the LD340 but says it makes more power.
Old 09-04-2017, 03:04 PM   #7
SSDiv6
It made more power after it was ported.
Old 09-01-2017, 12:12 PM   #8
junior barns
[QUOTE=Greg Hill;543675]He's already changed![/QUOTE
lol If thats the case, from the HP #'s gained from this that i've been hearing, he probably would be very competitive in your class right now!
